Assistance on new cart
ICOREM
18
2
135
Hi all
I'm looking for a new cart for a Ortofon rmg-309d arm [my other arm/cart is the Reed 3p + Zyx Optimum]. Turntable is Brinkmann Balance 2 arm.Phonostage is Soulution 550.
I love the Zyx but i'm looking for a different animal so I will have a different sound than the Zyx on my other arm. There is also an option to upgrade the 2nd arm from the Ortofon to maybe a Kuzma 4point.
my short list so far is :
Lyra Etna SL Lambda
Koetsu Coralstone or Blue lace
Miyabi Labs Fuuga
I would appreciate your opinions.
Thanks - Itay
shakti
1,444
2,411
480
Cologne, Germany
ICOREM
18
2
135
Thanks Shakti
I do believe that my phonostage can handle the 0.2mv output but it might be that thw SPU will benefit from a SUT. I had before the SPU century a SPU meister silver with great results.
ICOREM
18
2
135
Anybody else can share his thougts on my original questions above ?
I will add to the short list the Air Tight Opus -1 [some described it in this forum as very similar to Zyx while others thought it is very different].
Thanks
Reactions: Ron Resnick
ICOREM
18
2
135
Thanks Albert
Can you elaborate in a few words on its virtues and comparisons [if you know] with Koetsu and Zyx ?
Tango
4,938
6,269
950
Bangkok
Thanks
The Opus1 is very different from your ZYX Optimum. ZYX Universe is also very different from the Optimum. The presentation of the Universe is more similar to the Opus1. The Optimum just draw a picture of its own in term of presentation. I haven't heard these carts in other systems though.
ICOREM
18
2
135
bonzo75
22,649
13,683
2,710
London
Hi all
Lyra Etna SL Lambda
Miyabi Labs Fuuga
Thanks - Itay
Coralstone is one of the worst carts. I owned one that I tried on the kuzma xl4 and 4p art a friend's (dctom) and since have heard others.
Fuuga and Lyra are so different. Haven't heard the lambda but all other lyras are very different from the fuuga. You can't choose one over the other if you like both, you will need both. If you don't like one of them the answer is easy. But only you will be able to say that after listening as they are different flavors.
I am a big fan of the brinkmann balance.
Here in the link below you will see links to various brinkmann balance systems with other carts. Generally, both a full, grounded cart goes well with it and also a clean fast cart. Having not yet heard the lambda, If I owned a balance 2, I would have a SME 3012r with vdh Stradivarius, a brinkmann arm with a fuller sound like zyx or airtight, and choose based on personal preference. With more funds for an arm, I would install a linear tracker with top wing red sparrow. If you are not much of a classical and jazz person, drop the vdh and the red sparrow.
http://zero-distortion.org/brinkmann-balance-2/
bonzo75
22,649
13,683
2,710
London
One of the owners listed in my articles owns the balance with the koetsu jade with diamond cantilever, koetsu urushi, Decca London, and various SPUs. Stay away from the koetsu
ICOREM
18
2
135
Thanks Bonzo
What is your take on the Air Tight Opus ?
