Schroder LT magnesium arm tube upgrade!
audioarcher
1,396
51
970
Seattle area
I have had this arm for over three years now. Really had no complaints, but when Steve Dobbins told me he had an upgrade for it that I had to hear, it peaked my interest. After a few months I decided to go for it, and I am glad I did. The upgrade involves replacing the wood arm tube with a forged magnesium arm tube with a ceramic coating in my case. You can also get it with a clear urethane finish if you like. It also has a Teflon sleeve inside the arm tube for additional damping. Another change is the vertical axis bearing is upgraded as well.
The magnesium version has been in my system for a couple of months now. Been really busy lately, but finally have more time to listen and enjoy. This arm is quite a bit more resolving now. The noise floor has dropped a notch or two. Usually when you change something there is some sort of drawback but I don't hear any with this upgrade.
I will add photos when I figure out how.:) Getting an error when uploading for some reason.
XV-1
3,619
2,629
1,860
Sydney
the Schroder is the only tonearm that I have any interest in after I bought the Thales Simplicity II. the pivoted linear design in superb and it seems to work without a hitch.
The wood tonearm always left a small bit of doubt for some reason. I am sure the magnesium arm tube upgrade must be a great upgrade. And I see you use a technic motor as well - nice setup indeed.
Yes, we need pictures.
arnies
104
88
1,583
Austin, TX
Congratulations Sean on having your LT upgraded to the Magnesium arm tube. Steve brought one for me to hear to compare to my LT arm with the wooden arm tube. I agree with you that I could not hear any drawback to the arm at all - just positive sonic improvements in resolution, speed, high end sparkle and better textures. I purchased that arm and had him upgrade my LT arm to the magnesium arm tube version.
Arnie
audioarcher
1,396
51
970
Seattle area
Arnie
Thanks Arnie. I did not get to do a direct comparison like you did. Even so, it was quite obviously an improvement. The fact that you had the old arm upgraded as well, speaks volumes.
audioarcher
1,396
51
970
Seattle area
Hi XV-1, The Thales Simplicity II is an interesting arm. I heard the first version at RMAF years ago. The sound was good. I would like to hear the newest version though.
You have quite the collection of turntables. Which table is the Simplicity II on?
XV-1
3,619
2,629
1,860
Sydney
Hi Shaun
I do like the old Japanese DD tables. The Simplicity II is normally on the TW Acustik, but I bought a Technics SP10 mk3 recently in the technics plinth to try the Simplicity on the Technics. I managed to do that a couple of weeks ago. Sounds great.
cheers
audioarcher
1,396
51
970
Seattle area
Hi Shaun
cheers
Nice! I heard the original Thales arm at a show as well. I don't remember what cartridge it was using but remember it sounding very good. At the time I wanted one but it would not fit on my turntable due to it's design. It needed to be mounted very close to the platter which is a no go for the Technics.
16,219
13,698
2,665
Arnie
Hello Arnie,
What cartridge are using on your Schroder LT?
16,219
13,698
2,665
Hello Sean,
bonzo75
22,647
13,677
2,710
London
bonzo75
22,647
13,677
2,710
London
Hello Sean,
His forum details have it - colibri. So both of them are direct drive with Schroeder LT. Technics and the Kodo. That's how I would end up if I had the money.
bonzo75
22,647
13,677
2,710
London
Do both of you have this silver or copper wired? And the cost includes the wire running directly to the phono?
How easy is it to replace and armwand of an existing arm?
arnies
104
88
1,583
Austin, TX
Hello Arnie,
Hi Ron,
I have 2 of the Schroeder LT arms, both with the Magnesium arm tube. One was a new one from scratch with the Magnesium arm tube and the second one is my original LT arm with wooden arm tube that has since been upgraded to the Magnesium arm tube version by Steve Dobbins. Both of my arms use the silver tonearm wiring. On one of my arms I use the Lyra Etna SL cartridge and the other arm has the Lyra Olympos SL cartridge.
Arnie
16,219
13,698
2,665
Thank you, Arnie!
16,219
13,698
2,665
In actual use what are the sonic pros and cons of the copper versus the silver tonearm wire?
allvinyl
361
82
935
73
Burnsville, MN
What are the pros / cons of the wood .vs. magnesium arm tubes? Subjective based on cart used?
audioarcher
1,396
51
970
Seattle area
Hi Ron,
I ordered my LT with silver wire. Have not heard one with copper wire yet.
When I had Reed tonearms I had the silver wire option as well. Never had a chance to do a comparison of wire with the Reed arms either.
Steve Dobbins would be the guy to talk to about that. He was a Reed dealer in the past and is still manufacturing the Schroder LT in the US. He has heard most of the different versions of Reed tonearms, and of course the LT as well. His website is xactaudio.com.
audioarcher
1,396
51
970
Seattle area
Hi John,
It has been 4 years since I did the upgrade to magnesium. I also did not get to do a direct comparison like Arnie did. I cannot really add much to what I wrote in my first post. Maybe Arnie can add some info?
I can say I am still enjoying the arm, and I do not really feel the need to find something better. I am using a VDH Crimson Stradivarius on it now.
