Hi
I have recently purchased 2 of these panels to deal with low-end reverb/accentuation. See room setup below (my equipment rack is in the recess on the right side of the front wall):
The panels are 1m wide (by 1.5m tall) and so there isn't quite enough room to place both panels on the recesses of the front wall. Therefore I was planning on placing them on the very front of the side walls behind the main speakers (as suggested by the supplier). I'm now wondering if they would be better placed on the lower corners of the rear wall. I could run some tests with them leaning against the wall but they're not the easiest of things to move around.
A couple more graphics from REW in case they're helpful (with the first also showing room modes):
Thoughts? (The REW measurements above were before the new heavier and larger carpet went in. This has already made a difference to the sound of the room. On the rear wall I going to place 6 RPG Skyline panels for diffusion. I will then see how all this sounds/measures before looking at additional absorption on the side walls.)
Thanks in advance for the advice
Regards
Steve
PS: the front speakers are Egglestonworks Andra III (isobaric). I do not use the sub for 2-channel audio, only for LFE in video applications although I can use my Theta Casablanca to send LF to the sub and front speakers together. I've not played with this configuration yet but it would effectively be similar to a 3 sub setup. The Andra IIIs are good to 18Hz or so.)
Regards
Steve
