Question for Dr. Olive, Tom Mallin & Jeff Fritz: Wave Field Synthesis
Morbius
22
Just curious. What are your thoughts on WFS?
That's essentially how phased array radars work.
However, one problem I see is a lack of information. When recordings are made,
we only sample the wave at just a few points - where the microphones are.
If we had a "wall of microphones" at the recording session, and with a lot of computer
processing power - perhaps a "wall of transducers" could effectively replicate the
3D soundfield.
However, even the Krell musicians didn't make that type of recording.
It's a nice concept to contemplate.
Greg
tonmeister2008
WBF Technical Expert
Jun 20, 2010
210
6
Westlake Village,CA
This explains it precisely:
Gregadd
1,799
1,850
Metro DC
WOW!Double integrals, partial derivatives. I think I'm getting misty.
Morbius
22
..and with actual Green's Functions, sob, sob.
John,
Exactly!! Anyone familiar with Green's functions and differential equations would
be quite familiar with this.
Essentially the Green's function here gives you the response at (w,z) in phase space
due to an impulse at z'. If you integrate [ which is analogous to a sum in the discrete
realm, except integrals are in the continuum ], then you are just "summing" over all
driving inputs of that input times its response.
Greg
Gregadd
1,799
1,850
Metro DC
I used to try to decipher the math in Audio magazine. Remember Bert Whyte? Whenever Audio magazine wanted to proclaim a piece of equipment as the best they tried to bury their opinion in math.
MylesBAstor
81
1,725
New York City
Did you know that Bert Whyte had a huge R2R tape collection? A high-end audio manufacturer ended up with all of Bert's tapes-and remember that the engineers in those days used to trade tapes. So there are some spectacular recordings in that collection. Drool.....
JackD201
1,429
1,820
Manila, Philippines
I actually worked with a guy who didn't understanding anything or couldn't explain anything unless it could be expressed in an equation. I always wondered how he explained things to his kids before they got through algebra and calculus.
Sine Language? :p;);););)
FrantzM
29
405
Mark Seaton
WBF Technical Expert (Speaker & Acoustics)
May 21, 2010
381
141
390
47
Chicago, IL
www.seatonsound.net
3D soundfield.
Greg
While the question of having sufficient information is an important one, I'd suggest giving further consideration to the very significant difference from radar where audio uses a much wider bandwidth. Once you start including bandwidth that has very long wavelengths and you don't have an effectively infinite dimension to the array (by way of boundaries or spherical encapsulation, things get rather dicey for more than one listening position and maintaining behavior over a wide bandwidth. It's easy to define an array that works for a limited bandwidth, but just as is the case with speakers using multiple elements in an array, wide bandwidth complicates things greatly.
JackD201
1,429
1,820
Manila, Philippines
The music room conceptually would look like Professor X's Cerebro chamber. That would definitely be cool!
Oh Sean, is that how he managed to buy a secant home?
