IYou most Try order a yellow that is good start
What are you connecting to?In testing grounding my power in my depatment
To ground plate Why all ground cable is ConnectWhat are you connecting to?
Where All green yellow cable are connected i gone post a foto later working all dayHow to identify the ground plate in my own box?
I guess these are ground on my box. I've been testing using Magma Tungten Slim near the circuits for the Music server room and listening room. Been using the ugly tape until I'm sure I want to keep them there.Where All green yellow cable are connected i gone post a foto later working all day
Yes there you Connect is it working With magma feetI guess these are ground on my box. I've been testing using Magma Tungten Slim near the circuits for the Music server room and listening room. Been using the ugly tape until I'm sure I want to keep them there.
Any different With magma slimI guess these are ground on my box. I've been testing using Magma Tungten Slim near the circuits for the Music server room and listening room. Been using the ugly tape until I'm sure I want to keep them there.
I believe there is a difference however I have yet to determine if the difference is greater than if they are used in other places, and also if it matters if I use Nano instead of Magma slim. So further testing is needed. I don't currently have enough Magma and Nano to go around, so I am having to pick the location that gives me the most benefit.Any different With magma slim
I talk to to perolov entreq he isa friend to me he think nano could be betterI believe there is a difference however I have yet to determine if the difference is greater than if they are used in other places, and also if it matters if I use Nano instead of Magma slim. So further testing is needed. I don't currently have enough Magma and Nano to go around, so I am having to pick the location that gives me the most benefit.
The Nano will be better, there is no doubt. But my Nano are all being used on top of power transformers on for LPS, AMP, and Power Conditioner. For me it's a tradeoff until I get more Nano (or perhaps something else)I talk to to perolov entreq he isa friend to me he think nano could be better
but he tolv me test Bought
Where Do you live in from SwedenThe Nano will be better, there is no doubt. But my Nano are all being used on top of power transformers on for LPS, AMP, and Power Conditioner. For me it's a tradeoff until I get more Nano (or perhaps something else)
Hello Roger. I have also experienced great benefits with grounding the safty ground to an Entreq box, but did it in a much simplier way. Entreq can provide a power plug (shuko only) for the Eartha cable. It only connects to the safety ground of the power socket, not to the live and neutral wires of the receptical.Where All green yellow cable are connected i gone post a foto later working all day
I have testing grounding my speaker insideHello Roger. I have also experienced great benefits with grounding the safty ground to an Entreq box, but did it in a much simplier way. Entreq can provide a power plug (shuko only) for the Eartha cable. It only connects to the safety ground of the power socket, not to the live and neutral wires of the receptical.
I suppose its much the same as g an Entreq box to a power conditioner (if it has a grounding screw, e.g. Puritan Audio Labs).
It should also be possible to remove the live and neutral pins from a power plug and only use the ground pin to connect the safety ground to an Entreq box if you dont want to get into the fuse box. In this way you can create something similar to the Entreq shuko plug.
I havent connected anything else to the Entreq box used for the safety ground. Same as you did. I dont want to risk any loops etc.
It does improve the music. In my case especially in the bass.
Grounding boxes designed to dump signal ground noise into the house (safety) ground come with a three-pronged plug where only the ground pin is connected to the box - the plus and minus pins are just for support. The Entreq design is supposed to dissipate this noise in a box of minerals (simulated soil). If connecting an Entreq grounding box to the wall socket ground improves the performance what does that suggest about Entreq's "box of dirt" design?Hello Roger. I have also experienced great benefits with grounding the safty ground to an Entreq box, but did it in a much simplier way. Entreq can provide a power plug (shuko only) for the Eartha cable. It only connects to the safety ground of the power socket, not to the live and neutral wires of the receptical.
I suppose its much the same as connecting an Entreq box to a power conditioner (if it has a grounding screw, e.g. Puritan Audio Labs).
I've taken to calling most of these grounding solutions 'Fancy Dirt' for this very reason. However, I am a great believer in Fancy Dirt and its effects.Grounding boxes designed to dump signal ground noise into the house (safety) ground come with a three-pronged plug where only the ground pin is connected to the box - the plus and minus pins are just for support. The Entreq design is supposed to dissipate this noise in a box of minerals (simulated soil). If connecting an Entreq grounding box to the wall socket ground improves the performance what does that suggest about Entreq's "box of dirt" design?
FYI: https://hifiplus.com/articles/going-to-ground/
Entreq is not very public about how their boxes are designed except that they contain various types of metals and minerals. The article in hifiplus describes very well what I mean, and I respect the CAD company as a very serious player in the hifi business. CAD and Entreq are doing very similar products, and both have upgraded their lines in recent years. CAD certainly looks better, but I cant say which is the superior.Grounding boxes designed to dump signal ground noise into the house (safety) ground come with a three-pronged plug where only the ground pin is connected to the box - the plus and minus pins are just for support. The Entreq design is supposed to dissipate this noise in a box of minerals (simulated soil). If connecting an Entreq grounding box to the wall socket ground improves the performance what does that suggest about Entreq's "box of dirt" design?
Almost always electricity enters over the live line to the components, travels through primary windings and exists over neutral. Neutral is not connected to any other place inside components. If it is a single ended design then all negative signal ends connected to chassis and ground of power cord. Most probably noise is not coming from any other place than signal itself because single ended means it runs over one line and that’s the hot line. If you disconnect ground of power cord then signal ground or chassis travels to neutral inside power transformer. You need a good ground for signal to flow properly not to eliminate noise. Noise is secondary objective.This begs the question where it noise is coming from and which component is the most sensitive to high frequency noise. Noise on the live and neutral lines of the power cables is definitely detrimental.
