a musical journey - Aries Cerat, various devices
Yes, that was my plan. About a year ago, I was badgered into trying the Lampi Pacific direct to my 300B amps. I was amazed at how good it sounded. I immediately sold my preamp and said I would never buy another. I listened to the Horizon direct at the launch and thought the same thing.
To be honest, I had no intention of buying the Essentias. No, I did not listen to them prior to me buying but I did talk to at least 6 people who are knowledgeable and I trusted their judgement.
I know I said I would never buy another Preamp but it looks like if I can just convince my wife, I am going to order the Ageto in early 2023. Who knows, I may go to an all-AC system. It is one step at a time.
So @Willgolf - how are you finding your new Essentia’s?
Reactions: musicfirst1
Reactions: christoph
Oh My :confused:
Let me see whether I have this straight … Some John Doe registered since 2018 awakens like some KGB sleeper and in only his/her second ever post drops his/her pants and attempts to take a dump on a thread created specifically by the OP to chronicle his own highly personal journey with Aries Cerat Hi Fidelity audio components.
During the course of this particular bodily function John Doe neglects entirely to disclose his/her Commercial interests in … And Yes you might have suspected as much Dear Readers …
https://www-bellemusique-fr.translate.goog/?_x_tr_sl=fr&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=sc
Now, taking aside the blatant attempt to discredit another manufacturers electronics in favour of his/her own commercial interest, we must also consider the validity of the less that industry professional testing methodology as employed during this *claimed* A/B comparison between two pre amplifiers designed of disparate electronic circuit topologies as pointed out by subsequent respondents to this somewhat less than technical tour de force , akin to arbitrarily throwing a Moving Coil pickup cartridge into a phono stage system optimised for a Moving Magnet.
Any reasonably minded reader of this highly biased, in a technical / electronic circuit sense, and for my part I consider also one of highly erroneous personal bias , might *Also* like to consider the *Value* , if any , of throwing an otherwise excellent but disparate Atma Sphere MP-1 into a complete Aries Cerat system comprised of entirely miss matched optimum circuit requirements whilst connected to its *Alien* ancillary components via RCA connections only, and one for which it was not primarily designed.
I look forward to his / her next enlightening contribution to the forum with the same relish akin to having contracted Dysentery which manifest itself whilst wearing a deep sea diving suit!
@Aries Cerat, Is there any reason to think the Atmasphere MP1 pre would -not- be a good match with the AC Concero 25?
The MP1 is high gain which I’ve been told is best for AC.
The low gain Concero 25 is very low gain amp,requires a quite high driving voltage from preamp. (Not all AC amps are low gain btw).
The AS says 32v out max but doesn't say if it is VRms and if applicable for the RCA output.(some preamps have output spec ,for an RCA output , half of their XLR output.)
So to answer that in confidence,will need more info from AS .
If we assume 32vrms from RCA then answer is yes,with headroom to spare.
( especially if you use AC source).
cheers
S
I'm happily committed to the Atmasphere pre!
One possible solution suggested to me to avoid the rca halving of the the pre's output voltage: use two Jensen balanced to unbalanced full range isolation transformers. Pre > xlr ic > Jensen > xlr to rca adapters > Concero set.
Another more $$ option is to upgrade to the AC Essentia mono's.
You only live once!!!! LOL. I truly enjoy my Essentias.
These can work yes, though up to +19Db signal.
I would be cautious about available voltage and gain in the audio system. This coupled with high sensitivity speakers could result in a very limited/narrow range of the volume control. Anything above say 9 o’clock setting may potentially be too loud. Food for thought.
Charles
Reactions: Stef
Charles
Absolutely.that is why we are always considering total system gain and not individual components.you have to see it in holistic way,that is source voltage output,preamp max and min gain ,amp gain and speaker sensitivity.
Aim is to maximize useful range on the volume control.
Some designs have some features to help optimize the total system gain ,such as -6 db switches on sources and some preamps,and gain switch in some amps(Ianus Series amps).
Cheers
S
I did hear from Ralph at Atmasphere on their preamps voltage gain. He explained that their pre's use the balanced line standard where ground is ignored. The result is the same voltage (32V output max) used for both balanced and single ended.
