TAD R1 Mk2 vs TAD R1tx
Smokin' Joe
119
29
935
50
Melbourne, Australia.
Has anyone been lucky enough to compare the two? Is there a significant difference if at all???
I could be wrong but I thought TX was purely a cosmetic upgrade.
Just buy one Joe and tell us if any difference. ;) The new burl wood swirl is pretty.
i am not sure but the crossover at 250hz changed in TX model
Reactions: Smokin' Joe
All I could find
I saw them in person in Munich 2019; the European representative told me the crossover changed as pointed out above and that the front baffle was made more stiff as well as the new finish option being added but that's all I remember. He went on to say in a somewhat indirect way that sonically the Mk2 and Mk3 (the Tx) were close sonically.
Has pricing been discussed. I own the CR-1 MK2 version before the TX and saw the price almost doubled..... There must be a significant improvement one would think?
Selling my new TAD R1 tx and going down the Rockport trail. Price in AUD.
before selling any loudspeaker you should try to get good sound from it. I am sure if you can not get good sound from TAD then you will not get good sound from any other loudspeaker.
TAD R1TX needs mid to large size room, side walls should be 2m away from speakers it means the width should be longer than 7m (2+3+2).
the ideal room size is 8m (W) x 13m (L) .
TAD R1TX will shine with TAD M700 monoblocks not other ss or tube amplifiers.
the perfect match will be TAD D700/C600/M700 for R1TX.
check all AC polarity be positive and use Skogrand Cables.
use no AC filter, no tweak no tune.
for vibration use wellfloat boards.
spend over 200 hours for speaker placement using bob method : https://www.myspeakersetup.com/
I’ve had 4 pairs of TAD R1 speakers in my time, 2 pairs of Mk2 and this is my second pair of tx. I’m well aware what they can do and how to get good sound from them. The first pair I demo’d (and purchased) from Sydney Hifi were in a room that was only 4x5 meters and they sounded amazing. I’ve had my time with TAD and their speakers and now after 8 years I’m moving on.
My Mk2s also sound fantastic in a room that 12x18 feet. Personally I’d rather own TADs designs by Andrew Jones than one revised after his departure.
