Golden Gate 2 Reactions
astrotoy
1,551
1,020
1,715
SF Bay Area
Read the previous posts Larry.
Thanks. I see one for sale at t/c for $27.00 Chatham 5R4WGA - ceramic base "potato masher". Larry
astrotoy
1,551
1,020
1,715
SF Bay Area
Zero000
2,988
1,141
478
Super cheap because they made millions of them. Get the Chatham branded ones, or I cannot guarantee the results. In fact I can't guarantee anything in anyone's DAC, amp or system but it works brilliantly in my preamp and DAC.
wisnon
3,536
640
1,200
5R4WGA / 5R4WGB / 5R4WGY
(WGB=gray base) (WGY=brown base)
https://www.tubeworld.com/5r4.htm
also:
No difference. The 'real' Chatham 5R4 is the potato masher, you know, the really ugly flat top one that could be used to take over an airplane. Super thick glass, big ugly ceramic base 9either tan color or grey).
The ones I have are designated 5R4WGY. Later potato mashers made by Cetron don't sound as good.
Ditto. Mine are the tan base ones. Good sound from these ass-ugly rectifiers. I must admit I prefer the Brimar globes I have just because of their sexy good looks, but the potato mashers are quieter and have better bass. They're cheap too, I bought a half-dozen on eBay for $15, hard to go wrong with that...
Finally:
Hello ,
I have two pairs of this rectifier tubes is there any differents between them or i can use four 5R4GA instead of two 5R4WGB.
THX
The W code indicates special factory processing OR testing for military applications. There is no functional or performance difference between W and non-W.
The G code refers to the shape of the glass envelope.
The A code usually means that the tube is a revised design introduced sometime after the tube had been in production - usually to address some problem, or to make the tube suitable for a wider range of applications. However in this case it principally means a different shape glass envelope - smaller with parallel sides instead of a shoulder bulge.
The B code would also mean a design change, but I was unable in a quick search to find out what it is.
You would not use four of one sort of 5R4 instead of two of another sort.
You can easily check tube ratings at www.radiomuseum.org
The 5R4WGB was a ruggedized version of the 5R4GB specifically designed for use in military B52 bomber aircraft. It has an unusual shape, thick glass, and a molded base that extends partially up the sides of the glass. This shape has given it the nickname "potato masher". Because of its shape the 5R4WGB may not fit in applications designed for the 5R4GA or 5R4GB. The 5R4GB is an upgraded spec version of the 5R4GA. I believe the spec change is the PIV and peak plate current rating, but I am not sure. Verify before substituting.
All of these tubes are dual rectifier diodes with a common cathode. and all have similar plate current ratings. If you are contemplating using two paralleled 5R4GA's in place of one 5R4WGB, this may be possible, but may not be necessary. Check the plate current, peak plate current, and PIV ratings against your application.
The 5R4 types are particularly sensitive to the value of the input filter cap in 50 or 60 Hz applications. I have seen them spark out on start up even with the suggested cap value.
Zero000
2,988
1,141
478
Thank you for all that information Norman.
My technical knowledge is limited, but presumably, the5R4WGA / 5R4WGB / 5R4WGY valves output the same voltage and current as a 5U4G?
Close enough for you not to care and go ahead and try it.
Zero000
2,988
1,141
478
is there a difference between the 5R4WGA and 5R4WGB?
Yes. The datasheet for the B variant indicates there is a constructional difference but it doesn't state what. The B variant had better QC.
astrotoy
1,551
1,020
1,715
SF Bay Area
Thanks, Norman. Turns out my Cary 2A3 Signature amps use Cetron 5R4WGB tubes. Never really noticed them. I think one burned out in the 16 years I've had the amps. Maybe I'll get a pair of Chatham 5R4WGBs Cheap enough to experiment. Certainly cheaper than the KR 2A3's or Psvane 2A3-TII greys. Larry
also:
Finally:
Hello ,
THX
wisnon
3,536
640
1,200
5r4gwb are RECTIfiers. 2a3 are DHT output tubes. Not comparable.
Blue58
899
685
1,155
London, UK
bonzo75
22,650
13,685
2,710
London
wisnon
3,536
640
1,200
It make not make a lot of difference, but its actually fraudulent to show one picture and deliver something else. The most important thing is how well the tube tested. Was 65 69 the testing score. You have a basis to complain...but it may not be worth it. Just reflect it in your feedback.
dctom
317
60
258
Wiltshire UK
www.davidcthomas.co.uk
Thanks Norman
I have been in touch with them
the seller said....
"Hi Dave very sorry we could not send the one in the original picture. This was our last one. It was indeed made by Chatham USA and rebranded by Haltron UK
CV717 is the military number for all 5R4"
the test numbers on the box I have show; 66 67 - what does that mean exactly?
Zero000
2,988
1,141
478
Thanks Norman
the seller said....
It means that both halves of the rectifier are functioning almost identically, I would imagine. They usually quote a minimum good value along with it.
How are you finding it sonically in your system?
dctom
317
60
258
Wiltshire UK
Thanks Justin
I have only managed to get a few hours on it so far - guess it needs to burn in a bit. First impressions are very favourable so far.
Zero000
2,988
1,141
478
After hearing the white based KR 5U4G, and owning the EML 274, I think the Chatham is quite a bit better than either.
Whilst KR and EML make some excellent triodes, I'm not really convinced by their rectifiers so far. I was going to order the KR RK recti, but not now.
