New Göbel Divin Midi
Zero000
2,988
1,141
478
Build the big one very few can afford, then sell them the scale model:D;)
Priaptor
929
19
FL
nonesup
1,050
626
355
Spain
I have been told that finally the Divin series will consist of three models
Oliver Göbel
19
35
78
Munich
www.goebel-highend.de
Hello all together,
I could read in some posts, that there is a bit confusion about our 2 new loudspeaker lines.
Please let me quickly give you an overview of our now two loudspeaker lines and the thinkings behind them in order to clear things up.
1.) The Epoque Aeon line:
The new Epoque Aeon line is always fully based on our patented carbon excellence Aeon bending wave driver.
Technology like the Epoque Aeon line is always a 2 way loudspeaker. A nearly full range chassis (our carbon excellence Aeon bending wave driver) covers the enormous bandwidth from 160 Hz till over 30.000 Hz! Only below 160 Hz the bass chassis are working.
Beside the other advantages of our world wide unique bending wave technology (ideal dispersion range, actually no moving mass, highest dynamic, …), we hereby also reach an absolute perfect time and phase behavior as everything is produced from one driver!
The thinking behind this new Epoque Aeon loudspeaker line is to offer an absolute time and phase coherent loudspeaker line, which is fully based on our patented bending wave technology with all their world wide unique advantages for ultra high end connoisseurs, which prefer normal listening distances.
2.) The Divin line:
Technology like, this new Divin loudspeaker line are traditional 3 way dynamic loudspeakers on the first sight. With enormous bass chassis, 8inch midrange chassis and one big tweeter coupled over a big waveguide in one loudspeaker. All this membrane area is needed to reach a very high efficiency, which was one of the goals for the Divin line.
Beside the quiet traditional look of the chassis, we also massively used and applied our bending wave knowledge and technologies in order to perfectly control the membrane break up of the conventional membranes, reaching a best possible phase and time behavior and avoiding resonances in the membranes, in the enclosure materials and crossovers.
Additionally we developed the impedance of the Divin line to be max. even, in order to drive them with any amplifier, also with low wattage tube amplifiers.
Also the Divin line is able to take a lot of power and to produce sound pressure levels that rarely any other conventional high end loudspeakers can produce!
The thinking behind this new Divin loudspeaker line is to additionally offer a loudspeaker line for ultra high end connoisseurs, which normally prefers horn loudspeakers or more traditional loudspeaker designs, which are maybe also more into low power tube amps and also which prefers bigger listening distances.
The listeners worldwide don’t always like/prefer the same things and therefore we are trying to use our research and expertise to address these needs. It is our goal to provide the best possible quality, sound and solution for all our customers, dealers and distributors world wide.
All the best,
Oliver
Reactions: ozy and rsorren1
Stereophonic
891
674
410
Spain
Oliver.
Thank you very much for your explanation.
It is very intelligent and professional by your side to develope two different speakers styles.
Both has to me a lot of interesting resources and advantages
I’ll stay tuned to the Midi presentation on the 6th AE Show.
Congratulations...Göbel is growing with solid arguments.
Regards.
Elliot G.
3,348
3,082
1,910
Fort Lauderdale, Florida
www.bendingwaveusa.com
Elliot G.
3,348
3,082
1,910
Elliot G.
3,348
3,082
1,910
Elliot G.
3,348
3,082
1,910
Elliot G.
3,348
3,082
1,910
Elliot G.
3,348
3,082
1,910
Reactions: RideCA
Elliot G.
3,348
3,082
1,910
Reactions: RideCA
Elliot G.
3,348
3,082
1,910
I want to thank Kevin Wolff for showing me a little set up trick and pointing me to a new tool to help me take my set ups to a new level.
The Divin Marquis in my room today has taken me to a new place and one that I had no idea was there.
I have been lazy since returning form PAF but the last few days with all the gear settled in and warm I was able to make a few minor , teenie , tiny adjustments and the result is incredible
I want to thank Jeff Beck for stopping by and playing " a brush with the blues" from Just me with Manu Katche and Pino Palladino and absolutely blowing me and my crew away.
Elliot G.
3,348
3,082
1,910
Elliot G.
3,348
3,082
1,910
Elliot G.
3,348
3,082
1,910
