Munich High-End 2018 Ron Report: Ascendo Subwoofers
16,224
13,690
2,665
In 2016 Ascendo Immersive Audio unleashed upon the universe a 50" diameter subwoofer driver.
Now Ascendo has added a 24" model (good down to 10Hz) . . .
. . . and a 32" model (good down to 7Hz).
BruceD
1,517
587
540
Ha! --The "Lease Breakers";)
Great reports Ron-much appreciated!
And Glory be !-- all Pics perfectly rotated:)
BD
16,224
13,690
2,665
I discovered that rotating portrait photos four times before posting solves the problem.
BruceD
1,517
587
540
Really?-4 times!-- Try just opening your Jpg--then rotate as needed --then SAVE AS adding letter or number--so the file is another copy.
So--- Munich.jpg after above becomes Munich1 (or A etc) .jpg.
Even if the file first opened appears correct rotation--I'd still Save As and add the extra. Not too bad say use 1/2/3/4/etc/etc.
But if you are happy with your present method for now--fine--try the above next time:)
BruceD
