added a 3rd Studer A-820 Mk2 with both 1/4" and 1/2" heads, guides and hubs
Mike Lavigne
Apr 25, 2010
12,603
11,695
4,410
Nice tape deck Mike but maybe another brand for a change
been there, done that. at one point (2011) I owned 7 tape decks. in addition to the one's in that picture, at that point I owned a pristine Technics RS-1500, a really fine Nagra IV-S, and an Ampex 351. prior I had sold my de'Paravincini modified Technics RS-1700. so I learned that in some things variety is just that.....variety. I want to have the best tape decks......and I think that the A-820 fits that view for me. YMMV.
Reactions: andromedaaudio
Mike Lavigne
Apr 25, 2010
12,603
11,695
4,410
Mike, I think dubbing with the stock electronics, from one 820 to another, is ideal. I use my Doshi for listening only. It would seem to me that if your goal to create a 2nd version of the original which is as close to the original as possible, using stock would be your best chance to achieve that.
thanks David. I expect to be very happy with any dubs I make with this work flow once it's tweaked and I know how to do it.
Tango
4,938
6,269
950
Bangkok
I am just wandering should it matter what machine you use if, so happen, your playback or dubbing machine are not the same as the machine your original tape was made from?
Kind regards,
Tang
Mike Lavigne
Apr 25, 2010
12,603
11,695
4,410
Kind regards,
Tang
Dear Tang,
I can only speak as an observer; but if we look at what the Tape Project or what Chad is doing at Analog Productions; they both use a number of Ampex ATR-102's for their dubbing process. likely the same thing in Europe would be a Studer of some sort.
if one desires optimal dubbing performance; we start with top level transports, which means a very few master level recorders to choose from. the same things that separate these as playback units are doubly critical for a dub (pun not intended). then the heads and signal path, and while it's maybe easier to use identical heads and signal paths my guess is an expert could mix and match this stuff. however; clearly the experts choose to use all one type deck.
which bring us to me and my intention of eliminating as much ambiguity from my work flow as possible. I have no agenda to 'manipulate' any tapes. I don't need a mastering suite of 'flavors'. if I have a tape, then i'm already liking it just the way it is. and I want my dubs to be as close to an exact copy as possible.
andromedaaudio
8,500
2,850
1,400
Amsterdam holland
Yeah Nice , seems the itches to be scratched become limited. Lol
dminches
3,484
2,859
1,410
Kind regards,
Tang
What is most important in the playback machine is that it is properly calibrated for the test tones on the tape and that the azimuth is set properly. This assumes the deck in general is working properly.
For the record machine you need to make sure that the deck is properly calibrated for the tape you are using.
Obviously there are other nuances to consider but I think those things are at the top of the list.
16,224
13,691
2,665
Can I ask what is the purpose of your very unfriendly comment? Why are you bringing the Vivaldi stack to an interesting thread on analog electronics?
+1 as to both questions
16,224
13,691
2,665
. . . Nice tape deck Mike but maybe another brand for a change
I also think it is easier to find and maintain a service relationship with one service technician rather than having to find a technician for each model and brand of tape machine. I don’t have that many data points but the Studer technician in Los Angeles, California, literally will work only one Studer model. He literally will not work anything else but that one model.
Another Studer technician I am aware of will work only on a different model of Studer from the first one above.
andromedaaudio
8,500
2,850
1,400
Amsterdam holland
To be honest i only listen to tape in my new appartement, mostly my Telefunken M 15 A because it sounds great too and is a joy to use .
In the around 5 years i listen to tape none have ever let me down , i did have the studers recapped after purchase, not the Telefunken
The story that you literally need a tech at hand is not true.
Just happy listening thats all
I dont think the techs overhere discriminate , if they can repair a deck they Will , its there job/money lol
andromedaaudio
8,500
2,850
1,400
Amsterdam holland
Okay sorry micro may be i was a bit harsh .
But i work in the heavy industrybusiness we tend to be a bit rude may be in stating opinions
c1ferrari
May 15, 2010
2,162
51
1,770
[FONT=palatino\ linotype]Hi Mike,
So very cool and exciting! :cool:
I'm using a pair of A-820/2CH decks for a dubbing chain (4 headstacks/rollers: 2 quarter-inch + 2 half-inch) and a refreshed A-810 for remote recording (kinda heavy though, unlike a Nagra IVS ;)). I've decided to standardize on a Merging Technologies Hapi with premium cards for ADDA.
Hope all is well with the good people of the Pacific Northwest.
Sam
[/FONT]
Mike Lavigne
Apr 25, 2010
12,603
11,695
4,410
Sam
[/FONT]
thank you Sam,
I know you have gone quite a ways down the location recording road and had those multiple headstacks. I hope the multiple headstacks works for me too.
and all of us here in the Pacific Northwest are doing well other than lots of rain. :)
cheers,
Mike
Jan 18, 2012
2,373
2,476
1,475
Drobak Norway
great looking lineup
just one Q:
I also thought about just playing dubs of my safety masters to "save" them, but should they not be played once in a while for safer storage?
best
Leif
Mike Lavigne
Apr 25, 2010
12,603
11,695
4,410
just one Q:
best
Leif
based on my experience with my A-820's, I've found zero audible tape degradation from playing. and also i think that print thru and other bad things about storing tape long term is helped by playing once in a while. yet if there are tracks you like to play a lot, and can easily make dubs, then it might be a sensible thing to do.
obviously when pro's dub multiple copies they do use a working master dubed from the real master tape. but that could be a contractual requirement, or that master could be older tape formulations more subject to deterioration.
Jan 18, 2012
2,373
2,476
1,475
Drobak Norway
thxs 4 reply
same experience with my A80s.....haven´t noticed any "wear" and feel the tape is more "robust" than vinyl
best
Leif
yjwu
78
12
913
Taipei, Taiwan, Republic of China
Great setup! Suggest recording on mark-II to take advantage of its HX-PRO capability.
Bel Canto Musicale only has STUDER A807 as its on-site master recording gear, rolled by a cart. OTARI MTR-15, a great machine, was used to dub 2nd, 3rd generation tape. (Or they use DAT as mastering source? I have not owned any of Bel Canto Musicale's tape yet.)
http://www.bc-musicale.com/Zreel.html
In my case I had still not sorted out the recording-playback pair from A810, A820, A807 Mk-I, Mk-II. No doubt that one of them will be A820.
Where can I find a pair of 1/2" recording/playback heads? So far my 1/2" magnetic heads were for A807 four track or a A820-MR machine.
jazdoc
3,328
737
1,700
Bellevue
Good Lord, I leave you alone for one week....:cool:
Fischbach
2
Love to know what test tapes and signal generator you use to align your machines. Do you use a phase meter to set azimuth? What speeds do you use to playback and record?
