An all too human phenomenon. Reminds me of partisan blindness in politics, often affecting even very intelligent people.
Yes. But I think your political leanings are fine
Exactly. However, I think all of the contributor's to this forum have the same goal. That goal is to try and reproduce the sound of music as close as to what they hear live, in their own rooms. A lofty goal, but one that seems to have a slightly different satisfaction level to each and every member here.
I am 100% certain that the sax I was listening to last night would be recognized as the 'real' thing by all contributors to this forum...and for that matter to all people. The interesting thing, that I am beginning to realize, is that not all of us are as 'tuned in' to the sound of the what the 'real' sounds like as others....in the same exactitude. Nothing wrong with that, just an observation.
So frustrating to deal with you sometimes, Ack. Peter is absolutely right on this issue and you are dead wrong.
The VTF hardly changes during the VTA adjustment (Peter measured this), and that adjustment for each record clearly yields great benefits.
“Graham also likes to emphasize his arm’s neutral balance system. “There are three different ways to static balance an arm” Graham said, “neutral, stable, and unstable.” Stable balance, the kind typically found in lab scales, results when a moving system’s center of gravity occurs below the pivot point. Unstable balance, which Graham says is wholly undesirable for a tonearm application, happens when the center of gravity is above the pivot point. (When an arm is moved from its rest position, stable balance will create an opposing force in the attempt to move the arm back to the rest position, while an unstable balance results in a reduced force as the arm is lifted.) In a neutral balance system, such as the Phantom’s, the pivot point and center of gravity are in exactly the same plane, so when the arm is raised or lowered there is no opposing force. “As a result, Graham continued, “the only downward tracking force is provided by the counterweight, and there is no change in VTF as the arm and cartridge track our less-than-flat records.”
You just look for a pseudo-technical excuse not to make that adjustment yourself for maximum resolution. You always talk about maximum resolution, but you are constantly willing to leave resolution on the table? That doesn't make sense.
Could it depend on the arm, as someone else just old me? I easily measure 0.1g to 0.2g VTF changes in mine, with 2-3mm arm adjustments, and I can show you next time we meet - these figures are not what I would call "hardly changes", but feel free to share your own experiences. (...)
If you register such changes with a 2-3 mm arm adjustment it is a signal that probably something is wrong with your tonearm - physics says that a change of 2 mm height (less than 1% of the length of the tonearm) can not produce an almost 10% change in VTF. I have no experience with the JMW 10.5i but I would consider aspects such as wire tension any friction - if you measure it we must have a cause for it!
Microstrip cant believe you state something like this , if a good hifi system is actually capable of something believable its these kinds of music /instruments
Single instruments are misleading sources for life versus real comparisons. It was studied and documented since long.
I ll take that comparison anyday ,above cableswitching digital switching etc, studied and documented by who ?
A guy probably with a arm thick audiophile cable set or a refrigaratorsize powerconditioner ,
If live instruments is not what you re after then i dont know what is
I was responding to microstrips statement not you
Ps all those tiny differences audiophiles seem to hear not really interest me nor do I take it really serious
OK, we are all cool. While I still don't understand where andromeda was going with his post, I do understand now that he doesn't care about small changes, which is fine. But to me, a 4% change in VTF (tracking at 2.3g, variance of 0.1g) is significant (not sure where you got the 10%, micro, but it doesn't really matter). What frustrates me the most is when a scientist like Al uses bold language with no real solid personal data (only circumstantial), cites someone else's unverified and unpublished phantom data (thus, only hearsay), and provides no data of any kind from anyone (verified or otherwise). That's when I really lose interest... And yes, we are way off topic (speakers)... sorry about that.
Actually, I would differ...many can recognize the sound, but can't accept they have gone completely down the wrong path in choosing gear. I think this is not such a golden ears thing...people recognize the right sounds, they are just too blind (or is it deaf) to accepting that they went wrong in choosing the right path to recreate that sound. Also, people end up with their gear for a variety of non sonic reasons, which have nothing to do with what they would choose were they given a fresh start and a lot of resources to compare gear
or just simply that we don't hear the same.
for instance, some say SET makes vocals or instruments sound eerily real/in the room. I hear "holographic" distortion instead. who is right?
