Testing and embracing Stacore
PeterA
12,669
10,942
3,515
USA
Well Tang, my lp is actually 13” off the floor, but I get your point.
What is truly amazing is that analog should work at all sitting on a platform on the floor, way better than 3rd tier up in the air on a rack as was my previous setup.
And to allow my uber sensitive air arm to track like a bloodhound, playing on my springy 35x30 floor while maintaining cosmic levels of bass control, is the biggest advert for Stacore I can give.
Marc, how did you find setting up the turntable adjustments with the rig 13" off the floor, or did you set it up on a table and then move it? My friend has his SP10 III close to the floor and he can't see and bend well enough to clean the stylus, so he is planning a change.
spiritofmusic
14,626
5,435
1,278
E. England
Indeed we did set it up, move it, and then level the Stacore. I have few issues kneeling down to clean stylus, adjust speed, VTF and VTA.
spiritofmusic
14,626
5,435
1,278
E. England
About to order a custom extended top plate for my Stacore Advanced.
As is currently configured, I have to situate my Straingauge energiser box directly adjacent to my tt, which means only 2/3 of the tt is directly over the integral air bladders.
A wider top plate will enable me to properly centre the tt over the bladders while still allowing me to keep the energiser box next to the tt.
Tango
4,938
6,269
950
Bangkok
Sorry Jarek. I really like this pic. I can’t help not posting it.
Stress test my rack at 260 kgs.
Tang:)
flyer
423
179
1,160
Belgium
lol +1
Jarek is utterly transparent and honest by sending such pics :)
bonzo75
22,650
13,685
2,710
London
Lol
Stacore
641
196
180
Gdańsk, Poland
stacore.pl
Hahaha! This test was fun - the rack turned out to be solid stable under the load and i even managed to predict its fundamental frequency.
The paint is now setting Tang so a bit more patience please :)
Cheers,
Edit: The total load on top was 265+120=385kg...+100kg platform and a slate CLD shelf below
spiritofmusic
14,626
5,435
1,278
E. England
What’s Tang going to have on this thing, a whole gaggle of dancing girls?
If so, I want an invite!
spiritofmusic
14,626
5,435
1,278
E. England
Yes, but Tang is down on the farm sorting his fertiliser supplies. You only find real women down there .
spiritofmusic
14,626
5,435
1,278
E. England
Soon to order my third and fourth Stacore Advanced platforms.
I’m going to try these in four situations to ascertain maximum benefit
1- under preamp and cdp
2- under SETs monos
3- under tt motor psu & Straingauge energiser psu
4- under Zus
The idea to try them under Zus is the one that may produce the most interesting albeit unpredictable results.
I’ve got excellent SQ w my Zus on Symposium Rollerblocks & Svelte Shelves replacing stock spikes.
So Stacore should take this improvement to an all together better level. Mass loading and pneumatics isolation to both the main spkrs and integral sub amps & Lundahl transformers.
Most interesting will be the end result of raising the Zus 4-5” higher, which will effectively bring the Radian supertweeters up to ears level. That will certainly bring a higher energy presentation to the fore w the frequencies above 12kHz being more directly radiated twds my ears, together with likely benefits from SOTA isolation.
Tango
4,938
6,269
950
Bangkok
2- under SETs monos
4- under Zus
You are crazy man.
spiritofmusic
14,626
5,435
1,278
E. England
Tang, from the man who is certifiably insane with AS, Kronos, AF and EMT tts, I’ll take that as a massive compliment .
Tango
4,938
6,269
950
Bangkok
XV-1
3,620
2,630
1,860
Sydney
tang, from the man who is certifiably insane with as, kronos, af and emt tts, i’ll take that as a massive compliment ??.
lol
do you have child 3 & 4 yet?
Hieukm
271
105
128
Can you see 5 Stacores in this system?
I am thinking about Stacore but one thing makes me worry about my setup and this setup is the weight that the floor has to endure if put over 4-5 stacore. I am see almost a ton over such a small space. In my apartment it will be over 1.2 ton in slightly bigger space.
Stacore
641
196
180
Gdańsk, Poland
stacore.pl
Dear Hieukm,
Thank you for considering us! 1 platform = 100kg = 1 adult male (roughly). Imagine you throw a home party and 4-5 big boys come simultaneously to watch your toys. If your floor starts making noises, I'd run away from such an apartment saving your life! I'd be glad to help with assessing load per m2 and ceiling load capability shall you need it.
Cheers,
Tango
4,938
6,269
950
Bangkok
You win a set of our footers (when we finally make them :rolleyes: )
Cheers,
No need footers. Just send me a big sign “Protected by Stacore” to put on the wall of my room. The vibration karma will never enter my room.
Bests,
Tang
