Thoress Phono Enhancer vs. Aesthetix IO Signature
Tango
4,938
6,269
950
Bangkok
Hello Shaki,
I only tried the Thoress for a week in my system and used it for phono. My agent, just told me the Thoress can be used as tape head amp in P6. Is that true. And how does it sound?
Best regards,
Tang
Answering my own question, ha..ha.
The dealer for Thoress here informed me that the unit could be customized to do tape in P6 with eq for NAB or AES.
There is one person using it in BKK.
Tang
Mike Lavigne
Apr 25, 2010
12,603
11,695
4,410
Tang
my King Cello tape repro (output electronics) is also a phono stage. simply 2 separate EQ's with adjustable gain. and I've used it as a phono stage in the past and it's a pretty good one.
in concept a pretty simple task for a phono stage.
Calle_jr
160
14
250
Sweden
www.euphonia-audioforum.se
Yes.
Riaa has time constants 75, 318 and 3180µs with +/-20dB attenuation 20/20000Hz, whereas iec/ccir has only one time constant 35µs for 15ips with only 13dB attenuation at 20kHz.
Hence the Thöress Super Preamp would also be possible to adapt for tape eq.
The Enhancer is very nice, but I really doubt I find the non-riaa possibilities useful compared to the necessity to control four knobs every time I play LP or tape.
I'm not the type of person who marks knob positions on my records.
Does anyone know the gain of Super Preamp (mc version) and/or Phono Enhancer?
It's actually a bit strange to have such thorough information on the tone curve, but no information at all on gain or sensitivity.
shakti
1,444
2,412
480
Cologne, Germany
gain / sensitivity is not shown on the URL, as this customized to the individual order. My Thoeress is optimized for carts between 0,2 and 0,4mv ( others will work)
Calle_jr
160
14
250
Sweden
Thanks. Shure, but the high gain mc version is typically fitted with 100ohm, 560ohm and 1kohm resistors. Why not specifying the gain instead of a series of cartridges that "will work"?
As you know, VERY high gain usually has a trade off in non linearities. And if you don't need that extreme high gain it may be beneficial.
It's not stated for the CD or HP inputs either. Well, HP is zero I guess.
shakti
1,444
2,412
480
Cologne, Germany
all resistors / input impedance are customized as well, all offered gains do sound the same ( at keast I know three versions) , but Reinhard Thoress is open for discussions , if you feel like a potential customer, you might adress your questions/suggestions with the manufacturer
Calle_jr
160
14
250
Sweden
Yes, he's a nice man. Thanks.
I discussed with him about the tape eq already. I am a customer.
How should I explain myself... Manipulation of the frequency and phase response is inherent in a phono stage. Very high gain combined with riaa eq for arbitrary cartridges is not an easy task. There usually are negative effects which can be avoided with a little less gain. Otherwise millions of people wouldn't use a stepup. Thöress (and some others) have solved this satisfactory.
Still, I would like to know these specifications, not just that it "works". It should be fairly easy to design a calculator.
If you design the most beautiful phono stage with a gain of say 60dB, you can't just bias that for 70dB and say it sounds the same.
Gain comes with a price.
howiebrou
2,794
3,650
1,470
I am only now finding out about the Thoress phono enhancer as I look for a further or new phono as 3 inputs would exceed my AR Ref 2. At 9300 euros and 6 inputs it would seem to be a veritable bargain and I'm surprised more don't use it unless it has shortcomings that I have not read about.
I"m looking for a musical phono, not one that is only blindingly resolving. Would the Thoress fit this bill?
XV-1
3,620
2,638
1,860
Sydney
shakti
1,444
2,412
480
Cologne, Germany
One ground terminal for 6 inputs!! crazy stupid.
If you order new, you can customize. I had 2 ground terminals on my Thoeress.
shakti
1,444
2,412
480
Cologne, Germany
The separation of the rca plugs worries me a little. They seem on the picture to be very close set indeed. Would this prohibit some of the fatter cables?
The Thoeress is a full size PhonoStage, so fatter cables do work.
XV-1
3,620
2,638
1,860
Sydney
I know, I did the same thing on my TW/Thoress mk1 3 input phono stage. But it is stupidity that you even have to ask.
howiebrou
2,794
3,650
1,470
So my question is, would this be an upgrade from an AR ref 2? How about ref 10?
djsina2
1,172
1,018
243
The previous version had 2 by default. I guess this has changed?
djsina2
1,172
1,018
243
Here's a picture of the mk2 version. Notice the two grounds and also the "parking spots" for single coil mono. Maybe your picture is an old one?
