Is the Acoustical Systems Axiom Tonearm the Modern Fidelity Research or Ikeda?
dctom
317
60
258
Wiltshire UK
www.davidcthomas.co.uk
bonzo75
22,650
13,684
2,710
London
Is the damping you mention in the actual arm tube or via external troughs with fluid, à la sme etc?
Hi that should be a question for Shakti
16,220
13,684
2,665
Dear Tang,
Did you have somebody install and align the Axiom on your turntable, or did you do that yourself?
Tango
4,938
6,269
950
Bangkok
Dear Tang,
I didnt do it myself. Dietrich of Acoustical System came intalled it for me.
Tang
16,220
13,684
2,665
Great, Tang!
byrdparis
431
487
295
Israel
the acoustical systems arms are fairly self explain to set up, further more dietrich wrote a very thoughtful and vast manual to set them up easily.
(im a former Aquilar owner)
shakti
1,444
2,412
480
Cologne, Germany
Just saw this thread, mentioning my name sometimes, so I like to give a comment.
D Brakemaier has a huge and long lasting expertise with FR and Ikeda arms, so I am very much interestes about the comparison to his own development, the Axiom arm.
When I use the word „dampened“ for the latest version of Ikeda arm, I originally like to say, that the newest Ikeda 407 development is combining different metals in a way, that an effective resonance control is given . This resonance control can result in a more „dead“ sound to some carts, other carts (like SPU) benefit from the materials choosen.
The resonance control of the FR64s/Fr66s is much less effective, so some carts , with no fuerher need of additional damping/resonace control can benefit from this and play very lifelike.
Others do get a kind of „ringing“ and need some additional rubber on the arm to play
(like SPU)
The first Ikeda 407 arm had a steel tonearmwand as well, so very close to FR66s.
I never had access to an axiom arm and I am very much interested to get some first hand experiance!
I am reading the compatible Cart list, and I am thinking „whow“ as some of this carts mostly like different tonearms to be paird in the best way.
shakti
1,444
2,412
480
Cologne, Germany
....I never had access to an axiom arm and I am very much interested to get some first hand experiance!
Within this week (hopefully) my recently ordered Axiom tonearm will arrive.
(D Brakemeier is getting very busy in this Corona times...)
I am very interested to compare the Axiom to my Glanz 124 or the old Ikeda 407 (solid steel armwand) or the FR64s tonearms.
I ordered the Axiom in 12", with fixed headshell and fixed tonearm cable in Leica black. Hopefully one of my AF3P tonearm bases can be customized to host the Axiom, it seems, that only a M5 is needed and that all the necessary tools are coming with the tonearm.
16,220
13,684
2,665
I will be very interested in your comparison of the Axiom to the Ikeda!
shakti
1,444
2,412
480
Cologne, Germany
just found out, that "Audioquattr" is one step ahead, having the chrome Ikeda 407, the big Reed and the Axiom on his AF3P :)
Tango
4,938
6,269
950
Bangkok
djsina2
1,172
1,018
243
AS makes a SME adapter plate, if you happen to have a SME base.
Reactions: shakti
mtemur
1,413
1,362
245
48
I spent some time with Axiom, Ikeda and SAT. for me Axiom is a smooth and dynamic sounding tonearm. it's hard to achieve both of them at the same time. I think it'll match the dynamic presentation of Glanz but better overall. I think it's one of the best tonearms around together with SAT.
that's right it's easy to install and you don't need anything else.
shakti
1,444
2,412
480
Cologne, Germany
After some days with the Axiom, I like to share some thoughts and experience :
Prior to any listening, the fitting starts :)
The Axiom comes in a nice alloy case, everything has his place.
Reading the manual explains, the a M5 in 233mm is needed.
Dietrich Brakemeier sent me the SME adapter plate as well, so I had 3 choices:
- alloy 9' SME Basis (TechDAS AFV design) , to be used with the AS SME adapter
- alloy 12" Ikeda base (TechDAS AF3 design), space enough to drill the M5
- Micro Seiki AX6G Gunmetal base with already drilled M5 (originally for a tonearm rest)
So I called Dietrich to ask for advice. He explained, that the sound conductivity of gunmetal is higher than of alloy and that he would prefer for the Axiom the Gunmetal version, followed by the more massive alloy base and at last the usage of the adapter plate.
I liked this advice, as no need for drilling :)
The Axiom comes with 3 different solids steel spacers to get the correct base height to match the turntable platter height.
The spacer has 2 different sides, one with a small ring to increase the pressure in direction of the AX6G and to improve the energy transfer. The other side is flat and will become the surface for the 3 adjusting spikes.
On every turntable the tolerances of the parallelism of the platter surface and the arm base surface ist important and mostly not 100% given.
If you add the length of a 12" Tonearmbase plus the length of a 12" arm as such, you will see, that even 1/100 of a mm surface tolerance can become a serious adjustment situation for the Azimuth. As the Azimuth is in most tonearm Designs easy to fine-tune, the bearing of the Tonearm still "sees" this tolerance.
To my knowledge the Axiom provides on this matter a unique solution. Around the M5 screw are 3 spikes placed.
With the supplied spirit level it is now possible to tune the Axiom in the best parallel way, so that the bearing can move with minimal resistance.
Dietrich definitely prefers to reduce the forces to the bearing, so he likes, that even the tonearm tube as such is fitted in a parallel way only. All adjustments to the cartridge should be done on that place, where the cartridge is fitted, means the Axiom headshell can be used for the VTA optimization as well.
Following the instruction, the Axiom was fitted fast and straight forward. Like many "good old times" tonearms , the Axiom comes with lateral weights as well. It is possible to choose between 2 material in different weight to compensate different cartridge weights.
The counterweight come with 2 additional parts to increase the weight as well. An interesting fine tuning is now possible.
Every Cartridge (needle/cantilever, rubbering) assembly has its own spring constant, which can partly be seen in the compliance as well. You can balance a cartridge with a light counterweight and a bigger distance to the bearing or with a heavy counterweight close to the bearing point. This will change the parameters of the tonearm in a way, that a best match to the cartridge is possible.
70% of the VTF is static and to be done with the position of the counterweight. 30% of the VTF can be fine tuned with a magnet mechanism.
I am very sensible to VTF adjustments and I like, that with the Axiom this can be fine tuned during playing, so very easy to hear the "best" VTF. Antiskating is similar and can also be done during play.
Very special is the Axiom Antiskating. The Antiskating forces to the diamond of the cartridge are not constant over the radius of the platter. But nearly all tonearms only allow to adjust a constant force, which than is linear over the radius.
The Axiom provides a design feature, which is a dynamic Antiskating over the radius of the platter.
To work in the best way, the starting point needs to be defined. Installing of the Axiom has one parameter more, than other tonearms: The Distance between the headshell and the outer ring of the LP should be in the region of 8,5 cm.
My Axiom was ordered with a continues wire from headshell to XLR connector.
As first cartridge I have chosen the Mutech Hayabusa, as I know the cartridge very well and in different tone arms.
The Axiom comes with a full set of adjusting material, following the unique geometry of the AS AXIOM.
As you can see on the picture, a lot of parts need to be assembled to start the perfect placement of the cartridge.
But I could not wait to have the material assembled, so I only used the correct zero point .
Starting point of listening was all measurable on specification, means full parallel und VTF on midpoint of spec.
Now I am listening :)
And will describe later my first listening impressions.
IMG_4342.jpg IMG_4350.jpg IMG_4344.jpg IMG_4347.jpg IMG_4348.jpg IMG_4358.jpg IMG_4357.jpg
advanced101
247
179
233
Can't wait to hear your comparisons between the arms.
PeterA
12,669
10,942
3,515
USA
Shakti, Thank you for sharing these wonderful details about this arm. It certainly seems well engineered and executed. I look forward to reading your listening impressions later.
My newer SME arm does also have some of these features. Once can select between dynamic or static VTF, or some combination of the two, based on listening. I prefer the static force as I hear the dynamic force as too damped. The sound is not as lively, but the images and bass are more focused and "tight". Dynamic force (damped spring loaded) does help with severely warped records. The antiskating force is also applied with a damped spring, so I guess that is dynamic. SME also specifies a distance of the headshell to the outer edge of the record, so I do not think these are unique features to the Axiom.
I do think the VTA and azimuth adjustment at the headshell are unique and should have advantages as long as there are not compromises to rigidity caused by the design and many adjustments. I suspect not as it looks very well designed. Adjustability is usually an advantage. I also like the option of using more weight further from the pivot and comparing that sound to less weight closer to the pivot. SME does this too, at least with my V-12. Finally, I like what looks like the stylus being in line with the arm tube as a result of the offset headshell design. That is clever too. It looks like there is a lot of good design in this arm.
There are many features to like with the Axiom. I hope you share your impressions of the comparison with your SME 3012R. Congratulations. That is an excellent looking turntable/arm set up.
Reactions: shakti
shakti
1,444
2,412
480
Cologne, Germany
comparing the two Arms, SME V12 and Axiom, I see the following similarities and differences in VTF and Antiskating.
- SME and Axiom adjust both the static element of VTF with the counterweight position, fine tune is possible with the counterweight weight as such.
- SME is adding the dynamic element of VTF with a spring, similar to FR or Ikeda or Rega.
So you have the resonance of the spring being added to the construction. If you run a vacuum platter, so with flat record, mostly it sounds better to use only the counterweight for best VTF.
- Axiom has a magnet construction to add the needed VTF, so no mechanical contact at all.
- similar with Antiskating, SME (and many others) have a spring to add a Antiskating force. A spring has a constant force, if used in the area of the material specification. Again, a mechanic contact is given. SME needs to specify the distance of headshell and record to ensure, that the spring is used within the specification.
- Axiom is using an adjustable magnet and a kind of curved counterpart to fine tune the Antiskating over the radius with no mechanical contact. Axioms needs to specify the distance of headshell and record to ensure, that the magnet follows the specified correction curve over the radius of the LP
anyhow, both arms are great engineering and do make fun in fitting and using.
Reactions: PeterA
shakti
1,444
2,412
480
Cologne, Germany
The Acoustical Systems Axiom has given me some hours of pleasure with well known records,
I had in the meantime 2 carts fittes, the
- Mutech Hayabusa
and the
- Etsuro Gold
The Axiom comes with around 25g effective mass in the configuration I am using,
both carts do like this kind of heavier mass tonearms.
I know the Mutech Hayabusa on Ikeda 407, Glanz 124 and SME 3012R, so I was interested to learn about he Axiom effect.
And this effect is (at least in my system) very obvious, it immediately starts with more details out of the groove in the first moment.
In former times I had swopped the Hayabusa from Tonearm to Tonearm, I did the same with a Soundsmith Hyperion OCL as reference. The Hyperion is a better cart, than the Hayabusa, so in all of my three prior tonearms, the Hyperion was better than Hayabusa. Even with individual changed characteristics due to the different tonearms in use.
Fitting the Hayabusa into the Axiom Tonearm changed the game. The Hyperion was fitted into the Glanz 124, which works fine together. But the combination of Axiom and Hayabusa was superior in the area details, structure in the lower registers and precise staging. Only the vocals were still more engaging with the Hyperion. But as the Axiom with integrated connecting cable is new, it is possible, that with more hours of burn in, this will change and will become better too. To point it out clearly, the Axiom underlines my former experience, that a better tonearm can improve a cartridge performance by a huge margin, so that a simpler cartridge can sound better in the better tonearm, than the superior cartridge in the more simple tonearm.
(The Hyperion retails (in Germany) more than double than the Hayabusa, The Axiom retails more than double than the Glanz).
For this comparison I have chosen some of my older and well known records and I was surprised, that I was able to enjoy some of this moments, where you start to figure out, that you never heard that record with this level of coherence and detail.
Personally I do prefer on the most tonearms a copper wiring scheme, if I have the choice, I try to order copper. My Ikeda 407 has internal silver wiring and the Glanz arm has internal copper wiring. From the tonal balance I do prefer the Glanz arm.
The tonal balance of the full silver wired Axiom is more close to the Glanz presentation, even with the higher level of details, the presentation is far away of being "silver" bright. It looks like, that D Brakemeier still has some of his aged silver wires available.It is very rare to have this level of coherence out of a silver wired tonearm.
2 visiting friends had a bunch of Blue Note Tone Poets series records with them and we enjoyed an evening full of Jazz. My friends did liked my former hORNS Universum III speakers a lot for listening this type of swinging Jazz music.
There were a kind of impressed about the change in the over all presentation, as the dynamics of strong played piano, the natural and even sometimes aggressive character of a trumpet were so much better and very close to the former hORN performance.
After some days of music I changed to the Etsuro Gold, which was fitted before into the Ikeda 407 (old matt solid steel armwand version). This was than a kind of "über and beyond" shock. My expectations were high, as the Gold was performing nicely in the Ikeda 407, but the Axiom was so much better in all aspects The music was more integrated, more easy to follow, the level of details has increase, but not in pushing the details into your face, more in a soft and elegant way, if you are not looking for the details, they disappear as parts of a natural, authentic music reproduction.
My wife and myself love records with female voices, we hear a lot of the old Clannad music together. Listening to the nearly 40 years old live record (the white one with the red letters) was like joining a concert. Clannad were that time on a tour in Germany, which I visited (not the exact concert of the record, but the same tour) and I was never so close to the concert feeling before.
The price difference between Axiom and Ikeda/Glanz arms is huge, but you definitely get more out of the records and a much better connection to the music as such.
I cannot say, if the Axiom is worth the money, as I have no tonearm in this price region to compare on my AF3P.
But the Axiom definitely fulfills my former expectations to be a lot better than the tonearms in the segment of Glanz and Ikeda.
To get that level of performance it is important to use the capability of the Axiom of "dialing in" the cartridge,
that the cart can play at the best. It is part of the Axiom performance, that the adjustment of the cartridge can be done much more precise than with the most other tonearms I know.
16,220
13,684
2,665
Thank you, shakti, for this very interesting comparative report!
Since I personally care most about vocals, I am trying to trace through your report your comparative analysis on vocals. Is it correct that for vocals your favorite combination was Etsuro Gold on Axiom?
And with this combination, and I am interpreting what you posted, the Axiom increased detail which improved the suspension of disbelief, but the combination overall remained the most natural sounding and realistic?
Did you hear any tilting up of tonal balance or slightly greater presence range or high frequency emphasis along with this increase in detail?
Was this the combination that sounded with vocals the most in-the-room "real"?
Which combination most emphasized sibilance on vocals?
Was there anything about one of the other combinations which made vocals sound more smooth and more natural, even if less detailed?
Thank you!
