Ortofon A95
gian60
2,508
1,951
343
I bought a A95 and Sunday morning I will put on my Bergmann Sindre
I am curios to listen and do comparison with my Coralstone Diamond,GFS and Opus 1
Tango
4,938
6,269
950
Bangkok
In the future, just for fun we can do a trans continent cartridges loan :D. I also just bought an Anna.
Kind regards,
Tang
bonzo75
22,650
13,688
2,710
London
In some ways the a95 is similar to atlas... Dynamic, neutral, natural, detailed. I listened to both at Myles' and the Lyra did a bit of everything just more... With the price difference I would have gone for the a95. I also liked listening to it on horns universum
gian60
2,508
1,951
343
@ Tango
we can do also another loan
i give to you a tonearm Ortofon AS 309 S and you send to me the SAT
I am jocking.
If you want to buy also one Ortofon SPU A95 new,my friend closed his hifi shop in Italy and sell with 50% discount
Price in Italy euro 2.500,and he can sell for 1.250 euro plus delivery cost
gian60
2,508
1,951
343
What do you think Ked,
i can change Ortofon AS 309 S with SAT with Tango?
bonzo75
22,650
13,688
2,710
London
Tango
4,938
6,269
950
Bangkok
Thats a very attractive pricing. Your friends or you want to liquidate any Koetsu Coral or Bluelace? ;)
SAT is quite fragile in bearings. The sample that was sent to monoandstereo for test also had a damaged bearing. Once you take the protective disc out, I dont see how to put it back on.
Kind regards,
Tang
howiebrou
2,794
3,650
1,470
Kind regards,
Tang
Nice, i just bought an Anna too but not sure what tonearm to put it on...
howiebrou
2,794
3,650
1,470
I like my MC Anna. It doesn't get much play time however as I prefer the ZYX UNIverse Premium so much better
Steve, Could you briefly highlight the sounds signature difference between the two? What are they both mounted on currently?
Thanks
howie
DaveyF
6,129
181
458
La Jolla, Calif USA
Steve, couple of quick questions about the Zyx and the Anna. What loading are you using for both and what do you find is the difference in output between the two? As to output, apparently the Zyx puts out more output than the Anna...although the specs don't really seem to bare this out. If that is the case, do you have to increase the gain at the phono stage with the Anna in place to match the gain when using the Zyx?
Tango
4,938
6,269
950
Bangkok
Thanks
howie
You can read the review comparing the two carts in Mr. Steve's system written by Mr.Ron Resnick in monoandstereo sir.
Kind regards,
Tang
IMO there is just no comparison
The Anna is very nice but seems "polite" when compared to the ZYX. With my phono stage (Lamm LP1 Signature) there is no loading. There are 2 MC inputs. MC1 uses a SUT for low output carts and the MC2 input uses an SUT for a standard output cartridge. What I had Vkladimir do is to put the same normal output SUT in both inputs as it is most unlikely I will ever use a super low output cartridge
I agree that comparison is not valid as my ZYX is mounted on an SME 3012R arm and the MC Anna is on a 10.5" Graham Phantom Elite but everyone who has heard the two in my system prefer the ZYX Premium
DaveyF
6,129
181
458
La Jolla, Calif USA
Thanks Steve.
I understand that the Anna pretty much qualifies as an ultra low output cartridge...and in some ways so does your Zyx. However, apparently the Zyx is measured differently as to output. Nonetheless, I don't think the Zyx would likely have a lot more output than your Anna.
Do you have to apply a lot of gain on your LP1 with the Anna...more so than the Zyx?
BTW, I understand loading the Anna at 500ohms can bring some very nice results...may want to look into adding loading plugs upline of the input to the LP1.. Vladimir should be able to help with that.
Might even benefit the Zyx?? I have noticed that getting the loading correct with MC's can seriously improve the sound. Just a thought :cool:
Yes
not interestested Davey as IMO the LP1 is about as perfect as a phono stage can get. No way I want to fiddle with what I consider to be perfect
daytona600
727
154
955
scotland
+1
A95 + Lamm match made in heaven
DaveyF
6,129
181
458
La Jolla, Calif USA
Yes
Ok, thanks Steve.
Very interesting that you have to increase the gain with the Anna. According to Ortofon the specs on the Anna are: Output voltage at 1000 Hz, 5cm/sec. - 0.2 mV
and on the Zyx the specs are: 0.15mV (3.54cm/sec, 1kHz)----which somewhat confuses me as the output of the Zyx can be seen as 0.15 mv!! ( i.e., lower than the Anna; although at 3.54cm/sec vs. 5cm/sec??) Nonetheless, as I stated above, both are technically ultra low output cartridges and should not be easy to drive with any tubed phono stage! The fact that the SUT at the standard setting on your LP1 is apparently giving you sufficient gain is another head scratcher..but if it works, that's all that matters.
Tango
4,938
6,269
950
Bangkok
It must be Sunday morning in Italy now. Are you setting up the A95? :cool:
I will be putting my new Anna on Orofon 297. This will be on my EMT. The EMT arrived two days ago..still in the wooden crate..havent opened yet. I am waiting for the suspension platform of EMT to arrive so I could set up everything in one time.
Let me know how your A95 sounds. Btw, when you get bored with your Coralstone pls let me know :p.
Kind regards,
Tang
gian60
2,508
1,951
343
Today i am busy with my wife
this evening i will try,i will put on Bergmann where i tested Coralstone diamond,Opus 1 and GFS
