Why is Amsterdam known for second hand vinyl?
Because you can't roll a joint on a download?
That would be a red herring?
Well Tima, it's refreshing to know the Parabolica is an impvt all round over the 1.5, at 1/3 cheaper price.
Can I ask one q? If there is no speed change control, how does one manually adjust? Or is everything absolutely automatic, ie the tt always gets it right w no operator input? The owner switches things on, chooses 33.333 or 45, and the GP always gets on w it?
Indeed.
But what I'm also v interested in is what essentially you get in the 2.0 that fully differentiates it from the Parabolica (and hence 1.5 as well).
Are we primarily talking about the motor and the pressure sensitive clamp?
Ked, I really do believe that heft and bass extension you heard on the PTP Solid 12 is primarily a function of its uber high torque.
What you might lose is some air, and pinpoint imaging/soundstaging, due to inherently more noise from the motor/idler wheel.
If P Reinders has mainly sorted this w his twin stainless steel PTPs, then there is the mouthwatering prospect of drive and bass heft married to more than reasonable microdynamics, transparency and low level detail.
For me, low torque in any tt design seems such a contradiction.
I am fascinated to know whether housing the motor control unit internally is a great idea
My external one was an issue to effectively isolate noise ground wise
Thus the inability to isolate that by making it internal may be a good or bad thing
Ok, so which are high torque belts?
And low torque belts?
And where do Kuzma and Kronos fall? And Feickert Firebird?
That's the problem Tima, there are absolutely no specs on this.
It's purely based on here say, and personal experience of actions.
The Nottingham Analogs that require a push to get the platter going and can be slowed down by simple manual pressure at one end of the spectrum. The SP10s and 301s etc that get up to speed in less than two full turns of the lp, and can't be stopped by manual pressure for love or money at the other end. I know which end I believe a tt should be at.
