Tube Dampers
marty
4,212
2,520
United States
I'm curious about listener's experiences with tube dampers. I've explored old threads but the institutional memory here is very scattered and much of it is dated. I'd love to learn what specific dampers people have found useful, if any, and the sonic benefits that result from their use as it pertains to small tubes (12AU7, 12AT7, 12AX7, 6922, etc). Do they shorten tube life? It seems as though we go to great lengths to quench spurious vibration everywhere in our systems, so why are they not used universally?
Marty,
Have not done any comparisons to other products but the EAT damper for the 6922 seems well constructed and definitely is a snug fit over the tube.
I believe Lloyd (LL21) uses these and hopefully will chime in.
I have found my favorite of the few that I have tried are the EAT Tube dampers for the 6922s, 7308s. However, Brent Jessee makes big copper rings with siicone inside that worked for some of the larger rectifier tubes that i have in the PSU. The solidity of note is by far the most notable benefit in our system. Listening to solo piano is a great place to enjoy the improvement. However, it applies to all music. Plus with this solidity (described in reverse as lack of shimmer), there is also superior separation of instruments and improved detail/decay.
+1 for Brent Jesse copper rings. I use one in the PS of Zanden 1200 Mk3 phono stage and it works exactly as Lloyd described.
Reactions: thomask and mtemur
Hey Marcus...great to see you! I have just PM'd you for some advice on something else.
Hey Lloyd. Great to see you too. You have the answer...:)
Thanks! BTW, what tubes are you now using in your CJ GAT 2?
Still Ei Philips that came with the S2 upgrade. They showed some signs of problems after a month or so but they work now as they should.
Great! Thanks!
$10 audiophile branded or $10 for a pack of 20 (Silicone O-Rings high temp industrial 300deg C )
PCC88's?
I am using herbies on my tube preamp and lampi. The arc preamp has its own tube damper rings but I found the herbies better with more air around instruments. Herbies provide arguably some of the best compromises. My view of dampers is that you achieve a more solid presentation at expense of air.
Could I just wrap teflon tape in a tight ring around a tube?
I use silicone O rings from Grainger. Works great.
That is what I will probably try. I just need to measure my tube. I also looked at Brent Jesse's rings. I could use copper pipe and a piece of silicone to make it tight against one side. Not sure about the heat dissipation. Brents says it cools the tube. But I see a very small contact line of glass and metal. Seems more like it traps heat.
I’ve tried dampers, back when i had hope that some 2-digit investment would improve my equipment by a 4-digit amount. Wanted them to work, but really they did nothing. Fooling oneself doesn’t overcome the basic physics problem.
He really doesn't like 'em, does he? Lol
I've just looked at the Brent Jesse ones, they seem to nearly fully enclose the tubes, that can't be right, surely?
Reactions: Robert Young
