Rodney, but you bought the original G1s on somewhat a "buyer beware" basis?
And altered yr room upfront?
If it hadn't worked out, would you have got a refund?
If not, then buying Duettas w no home trial and abs no refund poss, is identical to the risk you also took?
How would he know since he hasn’t heard the Duettas? Given that you can easily get a duetta over to check out the bass, you will get a home trial. If you get a bass null you have a problem. It won’t sound as good as a properly done duetta but will tell you if the panels null out in your room or not. The mids will sound quite similar electronics aside, and you can always change crossover
I don't think that is at all reasonable Kedar. If I was Jon I wouldn't even entertain the idea given the access requires a winch.
IMHO there is much more than a bass null when determining is a speaker is suitable to a room. When using a panel you also need adequate room gain. Such a large room will be less critical to nulls than a rigid small room, as peaks will be less sharp. I agree with you the proper way is trying the speaker in place.
KedHi Steve,
This has been sitting in Marc’s inbox since morning. Can you please tell me why he hasn’t posted it? This is Bill’s representation. In case you think I am name calling, you should know that he will purposefully slag off Lampi incorrectly to provoke. I have nothing against him representing correctly, but to do so incorrectly is – well - incorrect
So based on latest info:
> GG performance with 242 and most importantly full grounding system has elevated it to the TT level and sometimes beyond / sometime less depending on material
> It has really become a software format issue not hardware issue now.
> Can the GG beat the musicality and stage of the TT with a great Decca or Analogue Productions - no. But the gap with grounding and 242 is much closer.
> let's see what happens when TT grounding is sorted.
> Also, if the TT setting is not spot on, it doesn't sound as good
Can Marc sympathisers please tell me how what he posted was correct?
Micro, I'm afraid home trial of Duetta now, or prob ever, is not going to happen
My access is 10' off flr level, no steps, my usual access via spiral stairs is off limits to 26" wide spkrs
And at the point I'd be ready, and financially prepared, to commit, the chance of a pr of Duettas to try in the room other than the commissioned pr, would be v slim or zero
Only if I commit will I set up the winch/pulley needed to pull this off, this in itself won't be easy or cheap, and will need careful planning
Btw can I ask what you mean by "adequate room gain" for panels?
The synergy of correct amp for the panel to fully, and easily, energise the room, and saturate it w bass?
No, rather like committing to an unusual horn or big flagship box spkr w no UK distribn, it would be buyer beware, purchase based on hearing a pr in a room vaguely as spacious as mine
I'd have to have really done my homework, and been confident on principle...
