The Day the page has turned for digital - 1/5/2017
Tapetech
143
24
328
Fairfax, VA
Perhaps in future MQA software decoders there will be a drop-down list of DACs to choose from so that the software can perform the needed "time corrections" for your particular non-MQA DAC. Then you should get the full MQA sound-quality potential.
MarinJim
888
2
http://tidal.com/us/masters
I'm looking forward to this. :)
For the life of me I cannot get this page. Downloaded Google Chrome, Adobe Flash, already pay Tidal $20 a month, emailed (only way of freekin communication) them for help and still get no "Masters". I click on "What's New" and only get recent releases (Featured). And click "Albums" and get only my albums. This on my MacBook Pro.
rbbert
3,820
239
1,000
Reno, NV
Have you installed the desktop app? You won't get the Masters otherwise (unless you have an MQA DAC).
audio.bill
550
91
340
Chicago suburbs
While I'm a Windows PC user, I believe I can be of some assistance. Currently the "Masters" heading to access MQA albums is only shown on the Tidal desktop app which is available at http://tidal.com/us/download . Once you download and install the Mac version of the software, login and you should then see the Masters heading within the Tidal app (you may have to scroll down to the second row of headings to see it.) Once you select it and "view all" you should be able to see the MQA albums displayed. If you then mark any albums you wish to hear as a favorite by clicking on the star icon within the album cover those selections will then show up as favorite albums under My Music in whatever other app you use while logged into your account (i.e. via Chrome, or another product specific app with access to Tidal.) Hope this helps, let us know either way. In time the Masters should become directly available in other apps, and Tidal should somehow visually designate MQA albums to differentiate them from other versions. MQA albums should also be made searchable by tagging a chosen field to uniquely identify them.
MarinJim
888
2
Thanks and yes I have. Tidal help is of no help. I have downloaded Tidal app 3x to no avail.
Blue58
899
686
1,155
London, UK
I had a similar problem and succeeded by going to tidal.com and downloading the Desktop version and not the version from the App Store which may be the iOS version.
So, to get MQA without the unfolding but at least a 24bit version you add the album to your library as has been mentioned. It then shows up on your iPad within Roon, for me at least, and I can then play the 24 bit version rather than the 16 bit version. Only trouble is most of the titles are not interesting to me ie. Fleetwood Mac or Phil Colin's.
The few that are I already have as hi res downloads.
Good luck with your endeavours.
Blue58
still-one
1,633
150
1,220
Milford, Michigan
Blue58
Please note. When we say the Tidal ap we are not talking about the one for your phone or iPad. There is a Tidal Ap for both Windows and OSX computers. You download this from the Tidal website. This is the one that you need to use for MQA.
MarinJim
888
2
The app for OSX is what I downloaded to no avail.:mad:
still-one
1,633
150
1,220
Milford, Michigan
MarinJim
888
2
And just for completeness, you are a Hifi subscriber, right?
Yes, of course. And now I have 4 Tidal downloads from PC+MAC. And this on the bottom:
* Currently lossless streaming with our Web player is supported in Chrome only,
** Currently TIDAL Masters audio is supported via our desktop application only.
still-one
1,633
150
1,220
Milford, Michigan
Sorry, I have seen that notation but it is not applicable for my application as I am using a MQA capable DAC.
MarinJim
888
2
Does it matter what DAC one is using with a MacBook Pro? I am downloading Tidal from my MBP.
still-one
1,633
150
1,220
Milford, Michigan
My MacBook Pro is not connected to my system. Tidal is streamed via SooLoos to my 808v6. I just use the Tidal OSX ap to identify what albums are MQA in the Masters section (or from the Roon spreadsheet) then go and select them in Sooloos.
MarinJim
888
2
^ My point is I can't even access the Masters section. It just is not there after, before, during any and all the downloads. When I select "Whats New" it is not even remotely seen/there.
still-one
1,633
150
1,220
Milford, Michigan
I know this is simplistic but:
Does Tidal show in your applications folder?
If so, when you open it from your applications or launch folder does it show you logged in?
If you are logged in when it opens you "should" see Masters listed under the "albums" section which is the third on down, after Featured and Tracks. I will be the last tab under albums following New, Recommended, Top 20 then Masters.
Don't know why you don't see it. The Ap doesn't need Chrome to see Masters, I guess just to connect your USB connection.
rbbert
3,820
239
1,000
Reno, NV
it really sounds as if you aren't seeing (using) the desktop app. What you describe is what I see when I just log in to tidal.com, not when I use the app.
MarinJim
888
2
You are right. It was in my app. folder, but I did not double click it to download. Thanks everyone for your help!:cool:
Now to figure out using MQA with my Audivarna+
egidius
430
5
923
Switzerland
..it'll work with A+3.0. Wait till June. .
On another issue: you and I both had wadia s7i, not sure if yours was also gnsc like mine. Do you ever miss it?
MarinJim
888
2
Yes, I also had the GNSC s7i. Great cdp, but (in my system) no match for my ModWright Elyse DAC w/modded Oppo 103 transport. I thought a source had to be ss, but ModWright changed that.
