Lamm m1.2
Eli08
240
1
Hi all,
Do you think Lamm M1.2 would be a good match with TAD R1? Don't have experience with LAMM but heard good things of them. Or the Lamm M2.2? Don't understand very well the difference between both of them? They are priced at the same point, but the 2.2 doubles the power although not pure class A, no? Which should be better with the TADs?
thanks
Eli
JackD201
1,429
1,820
Manila, Philippines
I've not heard Lamm with TADs but have used and installed both M models in various systems. The 1.2 has more bloom and more density in the midrange but gives up grip and propulsion to its sibling. This can be addressed with the 2.2 by simply changing the tubes. USN Amperex 7308s is an example of tubes that can help the 2.2 approximate the 1.2 Reference coincidentally for about the same price difference. The 2.2 is still heavily biased into class A for the first 40 watts or so so they don't give up much with delicate events played in less complicated music if at all they do.
The 2.2 is the forgotten Lamm overshadowed by their excellent and deservedly famous SET brothers and the multi-awarded hybrid brother with the Reference appellation. Despite this, over here it outsells the Reference 2 to 1. As noted, the price difference is tiny, about $300 only. One thing to remember is that the 2 series came after the 1.2 Reference and thus is more similar to the 1.2 Reference than even the M1.1 that preceded the M1.2. The top board layout is nearly identical.
I've run 2.2s with loads as easy as the Von Schweikert DB-99 and as difficult as Infinity IRS 3 main towers. For loudspeakers that are a difficult load to be used in large rooms and played at realistic levels I would recommend the 2.2. Otherwise, I would recommend the 1.2.
There were some very good reports of 2.2s driving TADs at Axpona Chicago this year. Some of our members attended. I don't quite remember if the speakers were CR1s or Reference Ones.
Eli08
240
1
thanks for all the details. There are both models being offer second hand at about the same, although the M1.2 has less time on it. But not sure if it will be able to handle the big R1s. The TADs at Chicago I saw the pics and was the R1s with the M2.2
JackD201
1,429
1,820
Manila, Philippines
Anytime Eli :)
joeinid
1,543
12
400
NY
Hi Eli,
The full size Ref Ones TADs are easier to drive than my CR-1's. 90dB vs 86dB.
What did you finally end up doing?
Thanks!
Eli08
240
1
Hi Joe, nothing really. I had one of my Omegas broken for some reason at the beginning of August. Will not be able to fix them for a while given everything is closed here till September. So thought I will try other things in the meantime.
I think if something needs to be upgraded in my system for a large gain (perhaps...) may be the amps, but not sure. I like the Omegas a lot but don't know what I may be missing. So was looking for second hand that I could sell easily if I din't like, that my be "different" to my amps. Also for demoing other top name contenders, which I plan to do anyway. May start a post at TAD or take over the one that Joost started.
In any case the guy selling the M1.2 never replied after 2 or 3 messages so i guess he sold them.
BTW, I replied to you question on the E1s.
joeinid
1,543
12
400
NY
Thank you Eli. I'll go read it. I need to give my TADs another chance. I have some tube gear coming and I am still urged to try Viola on them. Since getting my Revel Studio2 speakers, my desire to continue living with the CR-1's is on the decline. My Studio2 are even top to bottom and amazing performers. Maybe the Ref Ones might suit me better, but I am nowhere near making a commitment like that without extensive auditions.
Eli08
240
1
The R1s are better than the Cr1s. But the CR1s are fantastic to my likings. And at that price point nothing similar that I know.
Not sure if you have a problem with the CR1s highs, the R1s may be your thing. They are very similar there. The R1s have more weight, impact or body if you like in the presentation, more punch. All happens in a larger scale and with a majestic presentation - And then the main differences happen in the low end. But mids and highs are very similar.
If you can listen to the R1s at you place with your gear. I did commit to them without, but I did like the CR1s very much so was confident. But if that would not have been the case, I would not have committed without having a long in house audition. Your TAD dealer, having bought the CR1s from him should be able to provide this. Maybe the more extended low end helps you with the highs as well. But I agree: to commit on such money, you have to love the speakers and have 100% no doubt on them.
mojoetoo
9
alabama
Scheming to bring another pair of M1.2's in to drive an extra pair of Marten Birds for that veritable wall of sound. I may be way off but I'm thinking the 4 monos/4 speakers will provide oomph when necessary without strain/distortion while everything operates well within its own sweetspot. Lunacy? Would M1.1's mate well in this configuration or just muddy the waters?
ddk
6,261
4,043
995
Utah
Bi-amping definitely has its advantages, additional ease and overall more natural sound. It's always best to bi-amp with exact same amps, M1.1 & M1.2 share the same family character but aren't identical, M1.2 is more refined and open and has superior bass extension & dynamics.
david
Reactions: Amir
4,704
What is the difference between a Lamm M1.2 and an M1.2 Reference? At what time did the model change?
It's always AFAIK been a reference amp. I think you might be confusing it with the Lamm M 2.2 which is different the the M 1.2 Reference
4,704
I see - it was M1.2 Reference all the time. Thanks.
4,704
Question for Lamm experts: when connecting a Lamm L2REf to an M1.2Ref what type of cable should be used for best sound quality - XLR or RCA with shorting plugs in the amplifier?
As you rightly point out Lamm uses XLR which are shorted to create a SE cable.
Having said that I use XLR IC from my Lamm LL1 to my Lamm ML3 amps
JackD201
1,429
1,820
Manila, Philippines
Even if the L2 ref isn't balanced, I use XLR simply because it is a superior fit than RCAs.
4,704
Jack,
According to Lamm specifications and the Stereophile review the L2 Ref output is balanced :
pin 1 = signal ground;
pin 2 = non-inverting input (+);
pin 3 = inverting input (-).
If we use a XLR cable to connect it to the M1.2 it seems to me we are using a balanced connection. At less it seems so to me.
Input however is RCA only.
JackD201
1,429
1,820
Manila, Philippines
Well I'll be darned, all these years.... :D
Jack,
however you can get a Single ended Balanced cable which is what Nick did when he did my setup
Here is what he did
Pin 2 on the XLR to center pin on RCA, pin 3 on XLR to outer shield on RCA, Pin 1 on xlr connected to shield on XLR end and no connection on RCA
