Cat jl5
4music
50
Anyone has any first hand experience with the CAT JL5 especially the amorphous core version? In Feb 2015 german magazine HiFi & Records reports it as the best tube amplifier they have ever heard (they have also tested the JL2 recently).
Tim
ashandger
408
177
348
Do you happen to have an English version of the review? What other amps did they compare it to? I have owned the JL2 for many years so am also interested in the latest developments including the Amorphous core. Many thanks
4music
50
No english translation. I've used the google translate for the conclusions section.The original pdf can be located at the German distributor site.
DaveyF
6,129
181
458
La Jolla, Calif USA
Having heard many of the other CAT amps, I am sure that the new JL5 with the amorphous core is very special. I recently heard a new CAT Renaissance with the Black path cap mods...my new favorite preamp!
MadFloyd
775
1,700
Mass
Anyone know what the amorphous core is all about?
ack
May 6, 2010
6,774
1,198
580
Boston, MA
Usually it means low loss, but they have other problems... best to ask CAT about this. Changing amps again????
MadFloyd
775
1,700
Mass
Need something to drive my new speakers.
ack
May 6, 2010
6,774
1,198
580
Boston, MA
New speakers... OK; I must have missed a chapter. Or do you mean the Pass cannot drive your M-Pros...
MadFloyd
775
1,700
Mass
I'm thinking of getting S7's.
KeithR
5,174
2,864
1,898
Encino, CA
sorry to hear the M-Pros aren't doing it for you, MadFloyd - hope you can find a speaker that really suits you.
as far as CAT, working with that company requires patience. and you should be warned his amps can heat a small barracks :)
MadFloyd
775
1,700
Mass
I never said anything about my M-Pros not doing it for me. I hug them at least once a week and at 400lbs each, they provide me with lots of exercise. :)
nextlevel
3
Hello MadFloyd. I see that you are using the CAT JL7S! Congratulations! How is the sound compared to the Pass XS-150? Are you using the KT-150 tube?
MadFloyd
775
1,700
Mass
The JL7's have a richer midbass & midrange than the Pass which is more extended (as you might expect between tubes and solid state). Yes, I have the KT-150's which I love. Both amplifiers have their virtues. The Pass can sound a little more mechanical and steely in the upper midrange (the latter can benefit some instruments). I think the Pass is also more detailed (or at least one can perceive it that way due to more high frequency energy) and has a wider soundstage.
bonzo75
22,647
13,683
2,710
London
Hi so did you get the S7s? What pre do you use with the CATs?
MadFloyd
775
1,700
Mass
No, I never got the S7's. I was actually just attempting to get a rise out of forum member ack (of course it didn't work). I wasn't starting a second system and I'm totally satisfied with my M-Pro's.
I'm currently using the Pass XS pre with my CATs. That may change. :)
bonzo75
22,647
13,683
2,710
London
Always wanted to listen to a quality SS pre into a quality valve power. Normally get to hear the other way round. It would be good if you can audition the CAT pre and see the difference.
What differences have you found in vocals, tones of violin and woodwinds, brass, and general orchestral?
16,219
13,682
2,665
I am glad you are enjoying some of the virtues of tubes!
ashandger
408
177
348
Many thanks for the update. What is recovery of low level info such as hall ambience like with the JL7s? Are you using any support under the amps and what power cable are using? Look forward to further updates especially if you get to try a different preamp such as the Legend.
DaveyF
6,129
181
458
La Jolla, Calif USA
Ian, if you do change your preamp to a CAT, I think you will then see why I am such a big fan of Ken's gear.:)
