I could have posted this in the other thread but it has become so toxic I do not want to pour more oil in to that fire….
Listening to the audioquest jitterbug:
I borrowed a Jitterbug last Friday to try with my Hp Laptop running Jriver 20, RAM Playing files through the Chord Hugo connected with MIT Avt MA interconnects to my Amp.
The reason I was keen on trying this device is because although my DAC has sophisticated Jitter-reduction, Chord introduced Galvanic isolation of the USB input only in the HUGO TT and the 2Qute dac but due to limited space NOT in the Hugo. So even though Amirs Measurements suggests the jitterbug is not a conditioning device I thought if there is any chance of hearing a difference then it would be in this setup.
Well after a entire evening of AB Testing I am left a little frustrated, but not for the reasons you are probably thinking….
The improvements I heard with the jitterbug in place were minimal and it took me some time to be absolutely sure of what I was hearing.
With the Jitterbug there was:
- Slightly reduced sibilance which gave a more natural presentation
-Slightly blacker backgrounds
-Slightly better image dimensionality
The differences with just one jitterbug in line with the dac where way smaller than what you can expect from using a high end usb cable.
So you would think this is one upgrade I could live without right? The problem is that that 2% reduction in sibilance and gain in ease meant that over the course of a entire evening it was the difference between getting listening fatigue and not getting listening fatigue.
It has been some time since I have listened to only digital in one session and if digital was my primary source I would be trying to add two more jitterbugs to see if the difference is greater. But only AFTER I have upgrade all my cabling and software!
At 499$ you are being ripped off. At 49$...well you will ultimately have to be the judge of that.
The Spartan-6 FPGA in the HUGO
