Hear that it is viewed as heresy by the folks at Magico but was wondering if anyone has tried Stillpoint Ultra's under their Magico's and, if so, have any comment/observations to share.
I used to have them under my M5's and thought they made a big improvement. One they raised the speaker a bit which was good for my room, my ear height etc.... and they also allowed me to stabilize the speaker as I was part on a rug and part off. Do not have the M5's any longer and the M Projects I do have I am using the stock feet. Thread size is such that trying them on the M Project would be difficult.
Nice problem to have, btw....you can't use your Stillpoints since they would be difficult to integrate with your M Project...so two sets of four on my Q3's would set me back a bit
I talked to Mr. Wolf in Munich about that. He rolled his eyes when I asked him about SP. He basically asked me why would anyone would want to stand on rollers when trying to push/pull things, which is basically what a speaker does. He said that you want to couple the speakers, not decouple them. But he said that talking to Audiophiles about stuff like that is useless, as they surly believe that they know more about speaker design then the speaker designer, and/or accuse Magico of being bias (…as bias for good engineering is a bad thing). He said that the speakers will sound different for sure, but better they will not be, unless smearing the speakers impulse covers some other issues you may have in your system, but that is only further removing you from good performance. He also said that changing the height of the speakers is also detrimental to the performance.
Why? Who knows more about the product than the man who designed it? He provided several concrete examples of why using this product under his undercuts his design intentions and ultimately makes no sense.
Keep drinking the cool aid. Wilson says the same thing yet most Wilson owners use them because the speakers sound better. If I had Magico, I would have Ultra 5's under them.
Maybe, due to the weight, they no longer preform as designed and become couplers vs decouplers.
But in that case, you would be better off with a different design (most likely the spikes that are provided with the speakers...)
Also, Magico, being a sealed design, may react differently than Wilson and the B&W, once decoupled from the floor.
Not sure I agree with your comment about them becoming couplers (rather than decouplers) due to heavier size. I can't see how an Ultra 5 could become a coupler if it is set up properly
It is a question of the load they can carry, it is not infinite. Once exceed, they are no longer working as decouplers. I believe Gary Koh wrote a very informative piece on the subject here on your site.
Read up on stillpoints....as long as the ceramic bearings inside the device do not crush from the weight....they are diamond hard, the device will function as spec'd. Why don't you actually try them out rather than assuming incorrectly how they would work with no actual real world experience ? I suppose you could go on believing Magico makes the best footer for their speakers.
I would not recommend stillpoints under speakers. When I tried them on Wilson Alexias they were detrimental to the bass articulation and it makes sense to me that speakers should be rigid and not allowed to move along with the music.
I did try them, that is what sparked the conversation with Mr. Wolf. Since I don’t believe in reporting “listening” experiences, as I find them VERY personal, and rather than saying “I did not not like them” I thought it would be rather more informative if I explained why that may have been the case.
That's interesting as our own studio professional Bruce B has Alexia and swears by his stillpoints. Seating can be adjusted for the slight increase in tweeter height.
I would tend to agree with him and I always new this was their position on SP. But in the case I used them with success, the M5 and it's flat bottom caused a lot of instability and you could easily rock the speaker due to my particular setup. I think that by adding the SP I created a much more coupled speaker than what I had without them. Maybe some plane old tip toes would have been even better? But regardless I am very happy they have gone to the outrigger style base as it is much more stable and adjustable, I do not think the SP are needed any longer although as I stated before I have not tried them in my current setup.
