I just did a search on "opus111" and "S-D"...
I should have my NOS DAC in the system by next week.
---- We all wanna know all 'bout it! :b
PCM-1794? ...Not the PCM-1792?
Which NOS DAC?
Bruce has mentioned the next two DACs he's getting are Phasure and Lavry. Phasure isn't NOS, its multibit but quite the opposite in that its 16X OS. I reckon this is very bad news as it means the PCM1704s its using are 16 times more glitchy than with NOS. Bruce hasn't said which Lavry yet...
The Phasure NOS1 384 is a non-oversampling DAC.
Does a conventional DAC architecture (not DS) that is oversampled still suffer from noise modulation? I thought that was more a DS issue? Is it in the filter then instead of the modulator loop?
Bruce, I think you are mistaking the phasure as a NOS dac in the traditional sense vis a vis 16 bit r2r/current segment dac. While it is true that the phasure do not use oversampling and filter at the dac side, it is meant to be optimally used in conjunction with XXX high End, the audio player program which automatically upsample to 24/768 IIRC and applies Peter's proprietary digital filter (arc prediction) before sending the processed signal to the dac which then just output the signal as native 24/768. I would classify the phasure as a PCM high res dac.
Also, to use the XXX high end (which requires a lot of processing power) properly, the computer has to be very powerful and thus you have another problem, your pc power supplies will have to be really top notch (any standard ps won't do). Peter of phasure actually sell or help his clients assemble an optimal pc for XXX High End.
Bruce, the specs you posted earlier is for the discontinued 1st generation Phasure NOS1. The latest one Phasure NOS 24/768 will take signal up to 32/768 but I think output only 24/768. While it will accept 16/44.1 up to 32/768, this dac is meant to work best at 24/768 with processing done by the computers. Cheers.
I actually bought a used 1st gen model...
Here is another new development in NOS Dac, DDDAC 1794 NOS by well known german DIY. Whaddaya know, a S-D NOS dac, an oxymoron no?
The common thing with all the people doing NOS dac is that the digital filters is the main problem, it seems. Removing the filter function results in better SQ hearing wise.
Going back to Peter, he talks about frequency and time domain and feels that not a lot of thoughts/effort has gone into the timing side of things, which ties in with Opus's thing with CM distortion.
I have tried in the past, on more than one occasion to understand Peter's writings on CA. Each time I've given up after a fairly short battle - discretion being the better part of valour
