What preamp have I not tried?
Hi
IT seems that this hasn't been sugested in this thread.
Burmester?
011
077
088
808?
In my experience the best preamps I have heard even with non Burmester amps...
if your sticking with the Lamm amps, perhaps you should consider their reference 4 chassis preamp. I believe synergy between components from the same mfgr. matters.
+1 (plus the cable upgrades that has been discussed)
The M1.2s have psuedo balanced XLR inputs that can accept balanced signals as well as 2 RCA inputs, one phase inverted. No need for adapters :)
Jack,
As the M1.2s are pseudo-balanced this could completely change the situation - some balanced preamplifiers will sound better in real balanced differential than in RCA. I have found that ARC REF3, 5 and 40 sound and measure better in true balanced than RCA.
That's why I suggested FM Acoustics and SMc Audio. These two balanced preamps sound the same into single-ended, balanced, and pseudo-balanced power amps. The Burmesters, while excellent, would be better into a differential-balanced power amp. The SMc Audio also sounds the same with single-ended and balanced sources.
Good point. It's better to figure out where the sound issue is coming from rather than trying to find a component match to address that difficiency. More room treatment/bass trapping ?
I suppose if people are suggesting the speakers are a more difficult load...then an alternative perhaps is to leave everything as is...and consider changing the amp first to see if another one can drive it to suit MadFloyd's tastes better?
I admit i always expected Lamm 1.2 and Sashas would go well together. But Lamm is not the only combination for sure. The best i've heard the Wilson 8s sound was with MBL monos and ARC Ref 3 preamp. Sasha is quite different, but i have not experimented enough or listened critically enough given MadFloyds exacting focus.
MadFloyd - your comments focused mainly on transparency and articulated, clean and extended bass. It might just be worth leaving your system as is, and experimenting with an alternative amp? i am thinking serious muscle, SS, highly transparent with a touch of sweetness. Pass XS? Vitus? Gryphon?
To me it would be zanden 3000 and CAT legend .
But i dont need it anymore , as i m gonna sell the boulder and cat and stick with a integrated zanden
Wow! Congrats! I was wondering when you were going to make your decision! I am a big Zanden fan as you know. Congrats again, AAudio!
The zanden is in a bit of another class slightly above...
IMHO, Zanden definitely fits into the 'magic' category. Magic is subjective, but when you find it...well, it's magic. And that is all that matters. I am no expert either...i just enjoy Zanden magic. Enjoy your Zanden!!! ;)
It will probably be my last hifi , adding another zanden phono and i am set for the next 20 years .
I agree with you on zanden: it gives roomfill bassdefinition and triode reality in spades , although very neutral /relaxed , very very pure transparent sound and very dynamic as well , if one likes it it could be your last brand
+1000!
I know a few Zanden owners who have 'had it all'...and still own their Zanden equipment after all these years. One of them emailed me a few weeks to say he has just about gotten 'his Clearaudio Master Reference to match' his Zanden digital. That's first time i've ever heard anyone say that about TT v digital! And i think this guy is one who qualifies as having owned/tried a lot of SOTA equipment. He still owns all his Zanden equipment for the last several years.
Think the speakers are your issue. You need higher efficiency speakers.
Keith- I'm going through a similar process to Floyd and have Avantgarde horns, which are really efficient. The midrange of the L2 is pretty special, it's not tube warmth (the L2 isn't tubes anyway, except in the power supply, which may account in part for why it sounds the way it does), but for lack of a better word, the midrange 'voicing' is very correct spatially- it just sounds like music. The frequency extremes drop off and while what's there is ok, it is 'dark.'
I haven't tried the various other solid state preamps discussed here (or that Floyd has already tried), but the trick would be to get the highest frequencies and deep bass articulation without giving up that midrange 'magic.' Thus my interest in this thread as well.
I own an Ayre KXR Preamp. NO listening fatigue over here. My whole system is Tara Lab Golds IC's. Running Pass Lab Rushmore speaker / amps with new RAAL ribbon tweeters. The harsh highs you heard is not from the KXR pre. Noticed system cabling needs to come off the floor for a start, and maybe some room treatment.
I have bass trapping in one corner.From speakers showing listening chair.JPG
(the yellow circle is where I sit - in the corner you can see a RealTraps MondoTrap sitting on top of a hidden MegaTrap)
I do wonder if the M1.2 Ref is adding a bit of bass bloat. Next weekend I am going to Paragon to hear the Dan D'agostino Momentum (among other items).
I've never heard of Gryphon or Vitus, I'll have to research them. Pass XS is too big and hot for my room.
I have bass trapping in one corner.View attachment 5276
So, you are right against the back wall, and to your left, as seated, is an open archway leading to more space. Wonder if you could reposition yourself, get some distance from that back wall for one? I don't think the color yellow affects the sound, but Peter Belt may have a different view? :)
Here's another shot to show how open it does get. I have experimented with sitting closer (moving the chair you see in the pic in front of the couch). There's not a whole lot of difference in terms of bass. The biggest difference is not having my head right against the wall - which is why I use the yellow cushion to keep me bit forward - it works well).
