Willson Maxx - re-attchment of Grill velcro
GeoffC
1
59
A simple one - the speaker side grill Velcro on my MAXX's has started coming off pretty much everywhere and I'd like to simply glue back the Velcro. Is there an adhesive I should use or more importantly should not use as I don't want to damage / dissolve the foam and I want it to stay on. Thanks
dbeau
206
170
148
OKC,USA
good advice from Steve:
I had the same issue 2 years ago with X1s and Wilson sold me replacement strips specifically for the speaker.
Wilson will advise you on how to clean and replace the strips and it was easy with the end result being as good as original.
Good luck = not a big issue
