Which 12" tonearm for Miyajima Zero?
REXTON
2
53
Current stable houses a SME V-12 ands a SME 3012. I can't afford Glanz, so any recommendations would be welcome.
pweg
171
121
353
Australia
Glanz make a range of tonearms - 4 series. I have the top 2 and also several Miyajima. Worth exploring. What about an MH 9b or 10b ?
Petrat
24
23
83
UK
I've used the Zero on three different arms recently: Glanz MH-104S, SME 312, and SME 3012R ... the latter giving the best results for me, mounted on a Jelco HS-30 headshell.
So, suggest you try it on a heavy headshell on the 3012.
Reactions: bonzo75
Mike Lavigne
Apr 25, 2010
12,602
11,693
4,410
currently use my Durand Tosca (10.5") for my pair of Miyajima Infinity's (i have a 1.0 mil and 0.7 mil). previously i did use my Durand 12" Telos and it worked great.
the Infinity should be quite similar to the Zero. member Jazdoc does have a Zero on a Durand Tosca.
beaur
Fleetwood Sound
Oct 12, 2011
460
166
950
60
Brooklyn
I haven't had a Zero in my system but I do have the Premium BE. They are pretty similar with the BE being a bit heavier. I have successfully used it on my Schick 12" for some time.
Beau
bonzo75
22,650
13,685
2,710
London
The Schroeder BA works very well with Miyajima zero
Hear Here
744
460
155
Portsmouth, UK
I know nothing about this arm but owned it for a while after buying a job lot of first class but rather old equipment. Probably very rare but it's a 12" arm!
