What are the best headphones to wear while running?
bestman
3
Oxon, UK
www.dreheadphones.co.uk
I run about 5 times per week and I've had the same headphones for probably 9 years, although I only started using them for running probably 5 years ago. Naturally, the sound quality and (especially) comfort have been going downhill and I've decided enough is enough. Does anyone know of any headphones that are good for running? If anyone has any recommendations they would be much appreciated!
You need to be able to hear your surroundings, so sound isolation type phones is not a good idea.
Something open, comfortable, non-isolating. I really wouldn't worry about fidelity. What's your source? A smartphone? Might want to consider blue tooth. Lots of runners seem to prefer the "sport" style cans. Turn them down. You need to hear that car..
http://www.headphone.com/headphones/behind-the-neck.php
Tim
Just bought a pair of Jaybird Model Xs that I listen via Bluetooth
from an iPod nano when I run or workout. Very compact earbud design, you pretty much forget about them in use. No problem hearing enough outside sounds though they can subtly lose seal in your ear and you lose some bass.
The Jaybirds have noticeably better fidelity than the over the ear Sennheiser MMX100 BT they replaced (battery crapped out after a couple years), but being over the ear, they never slip.
I really like BT for exercise -- no cord to be annoyed by and with a BT Nano or similar, it's a very minimal rig.
