TAS Review: Klaudio KD-CLN-LP200 Ultrasonic Vinyl Record Cleaner: Ne Plus Ultrasonic
Peter Breuninger
Jul 20, 2010
1,231
4
Congrats on a great review!
rockitman
7,097
414
1,210
Northern NY
The review is no surprise. I will add, old records and even new need a pre hand scrub with brushes to maximize results. This applies to any cleaner ever made in my not so humble opinion.
Mark Jones
Jul 9, 2014
58
2
315
I want and need one!
XV-1
3,620
2,630
1,860
Sydney
Nice review
I have had mine for a month of so now and it is very good. expensive yes, however if you have a lot of lp's, amortised it is good vale. Around 55 cents per album for me.
cheers
Dre_J
478
1
Nice review
cheers
Thanks Shane
Dre
rockitman
7,097
414
1,210
Northern NY
I have this machine and the Audio Deske. Either machine benefits from giving records a pre brush/scrub w/ Enzo juice and dry prior to it's first KL treatment...
hifitommy
right you are Rockit! a spin clean would do nicely as a pre-wash device so you could put an uncontaminated disc int the higher cost device that recommends no solvent or cleaner. do i think $4k is too much? for me, right now, yes. yet i know a guy that is careful with his money that is right on the verge. one cold buy wisely, that is wait for a special price or sale or buy used.
rockitman
7,097
414
1,210
Northern NY
So what does one use as a hand pre-scrub?
I simply lay out two micro towels folded in half to lay the record on. I use audio Intel no. 15 pre clean Enzo juice. I use a disk doctor or similar brush and scrub each side. I use a folded micro towel to dry the record off after scrub, throw it in the KL toaster And you are done. After that, I only kL when needed for dust or static. I have yet to do a record twice. Without the pre scrub, finger oils and pressing solvent residue will not come off with ultrasonic cleaning alone. Elbow grease is needed with the Enzo juice.
Barry
273
54
1,220
Somewhere near Philadelphia, USA
I tried pre-cleaning with these bubbles and then with the KL Audio using more bubbles. Experimenting with different vintages. I'm having a difficult time keeping the pre-cleaning fluid in stock!
