Subwoofer EQs - what does good look like?
Nyal Mellor
590
4
330
SF Bay Area, CA, USA
So here I am going out to customers homes doing calibrations and I am constantly coming up against the lack of a good subwoofer crossover / EQ solution. Is anyone else having this same problem?
It got me thinking. What would a good subwoofer EQ look like?
- automated or manual setup? or maybe some combination of the two?
- FIR or IIR filters?
- how many subwoofers would it need to support? 2? 4? 8?
- what inputs would it need to have? XLR, RCA, Digital!!?
- how much should it cost?
- what are other people using and what drawbacks do those products have?
- would it incorporate a LPF? e.g. for rolloff of mains?
- would it incorporate a HPF? e.g. for subsonic rolloff?
My own preferences would lead me down the path of IIR filters, manual setup, 4 subwoofers, XLR inputs, yes to HPF, no to LPF, under $1000...what say ye all?
JonFo
322
1
925
Big Canoe, GA
www.jonathanfoulkes.com
I've used all kinds of stuff to perform what you outline. Everything from a Behringer DCX2496, to a DBX DriveRack 260 to my current piece, a DriverRack 4800. I've set those up manually, and currently use Audyssey Pro on top of the DBX.
I agree with you, there is no good focused piece below $1K for this application in home setups. However, there are a few pro-audio pieces that work quite well.
For me, here is my ideal low-frequency integration box:
Assumptions: A quality pre/pro is doing the main bass management duties and outputting a single LF/LFE channel. For 2ch system integration, box will accept 2 inputs and deliver 2 LPF outputs for mains
I'd start from an existing platform, like a 2x6 unit like a DriveRack 260, so you can support one or two channels of input and drive up six subs, or four subs + 2 ch of LPF output back to the mains.
Complete manual setup supported for proprieties like gain, delay, phase, global input PEQ, per output PEQ.
Filter types, all the usual LPF/HPF/bandpass with selectable slopes, and yes I'd want IIR implementation, and with today's DSP, that should not be expensive.
I/O would be XLR, but gain structure could be adjusted to adapt to consumer line-levels, so use of cheap physical XLR/RCA adapters would work well. Gain structure would be independent per input and output to allow for mix-n-match subs (some with XLR others without)
Digital I/O seems like a nice-to-have, but in the real world, when could it be used? no amps have digital ins, and the real problem here is volume control. Food for a separate thread, but what I'd love to see is amps with volume control signaling, so we could biamp and do signal processing on full-level digital signals.
As for automated solutions, one way to manage hardware costs is to move the logic and processing of the measurement system to a PC-based solution that can be an optional component.
The measurement software can either be a licensed solution like Audessey Pro, which can measure and set the gains, delays and crossover points automatically, as well as generate the correction impulse response fo the IIR convolution.
Our it can be a licensed version of Harman's SFM technique for using multiple subs to smooth out room response.
Matter of fact, what I've described above could very well be implemented by Harman as the successor to the 260, say an unannounced DriveRack 2600 (or a pro-sumer variant) as I know that using the same architecture as the 4800 (with their awesome HiQNet System Architect software) they could deliver all but the IIR filters (the DriveRacks are all currently FIR-based). Add in a PC based SFM measurement and control plug-in to the HiQnet solution, and you'd be set. Ping Todd Welti and other Harman folks on this board, and we might get somewhere ;-)
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,008
1,320
For what its worth, I have found that all sub EQ's only do half of what really needs to be done. Yes, they are an effective tool to get the sub sounding great to the room. I'm not challenging that at all. Have you ever considered a Velodyne SMS-1? I ask because I have had seamless integration with these units.
In a nutshell, what they do is [with a seemingly infinite array of custom or automatic settings] blend the mains to the sub and then both of them to the room. Of course since you can't make chicken soup out of chicken droppings, you are going to have to start out with proper placement of both in the room. The Sumiko setup can help with the mains and the typical placement of the sub in the listening spot and crawling around the room can help to achieve a location [for one or more subs] for optimum sub placement to your preference. After this has been done, the SMS-1 can make the entire system and room integrated as one. Instead of just blending the sub into the room.
Many times with a sub that had a 12" and a 15" active woofer along with a 15" passive sub in one inclosed unit [wired in mono and separately amplified] , folks would require that I take the cover off the sub because they swore up and down that the sub wasn't on, that they would be able to hear it. All I had to do was turn the SMS-1 off and they would discover that it was in fact on. What followed was the questions that typically started with "how'd you do that"?
It is not the easiest of gear to operate to sonic perfection but there are many avenues of help that are available. I'm sure that there is a learning curve with any software or other sub EQ products but it's not anything that you need to have a degree from MIT to properly integrate. It may not be the best available out there but two of these units either refurbed or on the used market will properly integrate two subs in stereo. One SMS-1 unit will only do a mono sub signal but as many as 3 or 4 [I forget] subs can be hooked up to the one unit. For just a little more coin over your 1K budget, you can purchase them new. I hope this helps.
FrantzM
29
405
Treitz3
What does the SMS-1 do that can't be done with a Behringer DCX-2496?
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,008
1,320
I apologize, I am not familiar with the Behringer DCX-2496 so I really can not comment. If it blends the mains to the sub and then both the mains and the sub(s) to the room, then I suppose that they are similar. From briefly looking at this page http://www.behringer.com/EN/Products/DCX2496.aspx I see that one main difference is that the Behringer does not offer RCA inputs and unless I missed it, it doesn't correct either the sub or mains to the room. It appears as if it is an active crossover that the user via the software can manually change things and I must admit, this unit has a plethora of really nice features.
That said, I don't believe that this actually records the frequencies allowing the user to subsequently adjust the parameters within the unit for the listening position. I could be incorrect but I didn't see anything that would suggest that it did. With the SMS-1, you take a mic and put it on a stand. Let it do the sweeps on both the subs and at the same time the mains. When you first get it, there is an "easy" button and the unit will automatically adjust the parameters for you. However this is not the preferred method. It's a great starting point to see what the unit does before you move along but the unit is capable of doing so much more.
Here is a review if you would like to familiarize yourself a bit more with the unit http://www.prillaman.net/sms1_review.html
The best way to learn what this does is not to read the horribly written manual but rather to download and print out the Outlaw's guide to the SMS-1 linked here http://pdf.outlawaudio.com/outlaw/docs/sms1guide.pdf You might want to brew a pot of coffee before you start reading, though.
I have found that for the best results, place the mic in different locations around the listening position and not just in one spot. This means above and below the listening position, in front of and behind as well as L to R of the listening position. I usually did the sweeps in the various locations about a foot away from the listening position. Take the average and customize everything to make it sound the best. This unit has so many options [read about them in the Outlaw guide linked above] that options are seemingly infinite. The good news is that once you are completely satisfied with blending your subs to the mains and both to the room, you won't have to worry about doing it again unless you just want to try out another preset you had entered when say, going from music to a movie. I usually just kept it on the one optimized preset and turned the volume on the sub up or down.
You have to have the test tones go through your rig via the preamplifier and once the sweeps are done, they do not need to stay in the input, however it is convenient to do so when you first start playing with it and making adjustments. The most important thing that you have to be 100% positive of is that the mains AND the sub are both operating when doing the sweeps. I can not stress that enough! Oh, one more thing. In my old listening room, I did not have a TV. I had to go get a portable DVD player that had a video input in order to see the frequencies and make adjustments. If you have a TV at or near your rig, this will not be of any concern.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
I like Audyssey MultEQ XT32, with two subs in a normal room's size.
* The manual dedication is all in the proper mic positions.
And the rest is automatic; measurements and all... :b
And I use my ears as the final judge. Because all the graphs in the world cannot tell the full story on all aspects of audio listening.
That's my own personal approach, and I'm always open to other approaches as well.
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,008
1,320
Eh, might as well throw this out there as well. A little bit of discovered trivial poop never hurts. I found through experimentation that raising the front firing Tyler Acoustic subs I have now increases the visceral impact, raises the sound stage and made the sound of said subs better. Being able to tell exactly where each drum is in the sound stage is no longer something that I have to strain to identify. You results may vary but in my case, it was a wonderful tweak. My subs currently reside on Target audio stands and the woofers are within an inch or two of the tweeter.
LOR, using your ears for final adjustments is something I should have mentioned. Very good point.
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,008
1,320
Nyal Mellor, have you made any progress on your inquiry?
4,702
Active bass cancellation
Many people refer that bass response of small rooms is the Achilles Heel of listening rooms and large area bass traps are often used to correct the excess bass of problematic rooms.
Some year ago I read an article by Jeff Fritz where he reported he used an Wilson WatchDog subwoofer in opposite phase to cancel a bass room of his music vault. Considering that inexpensive units such as the Behringer DCX 2496 have powerful equalization capabilities,including separate variable phase for each channel, why are not people using subs as bass traps?
Mat be this is not the best place to post about active bass cancellation, but since it can be basically achieved with equalization and a subwoofer, it is not completely out of subject.
FrantzM
29
405
Microstrip
I believe that Sean Olive started a thread on this very concept. This seems to eliminate nodes in a room, the idea is to have woofers in the front of the room and the exact same number of woofers in the back but phase-reversed. There is also a thread on the AVS Forum on this concept. A fellow in Swedenor Denmark ( Maybe another Scandinavian country) actually implemented this ... besides the labs or listening rooms of harman Kardon... Very interesting concept I would say .. I have found however that using multiple subwoofers following the Geddes method mitigates the nodes in the room and by a fiddling , level, crossover, phase and delay.
4,702
Frantz,
Many thanks, I will look to the references you suggest. I was thinking about applying these concepts to a pair of full range speakers that have some excess of measured bass even without subs.
