Speakers for Pass Labs Electronics ?
Axel C
12
8
8
NYC
Dear Axel,
Are you using a pre-amp between the Terminator Plus and the First Watt SIT3? Didn't see one.
Have an Audio Research GSi75, but am tempted to buy a Pass Labs or First Watt. Listen to mostly vocals, jazz, blues and some R&B. Grew up in the 60s and 70s so on occasion go back to rock from the period. Sounds like you recommend the XA25 as the compromise. But which do you prefer for piano, organ and vocals?
I also have a First Watt J2. Its true power is somewhere in between the SIT3 & XA25, as does its general sound character (to me). Warmer and less powerful than the XA25, but lacking a little bit of the magic of the SIT. Herb Reichert’s Stereophile reviews of all three can be found online and I think are excellent. All of the First Watt and lower powered Pass Class-A amps while different are quite special. And they are great bargains, especially if you don’t need big power. The X350.8 is ~4x the price of the FW products yet at lower volume levels is simply not in their class. In these situations, power is really overrated!
bozebuttons
41
18
13
72
I am using Piega C8ltds with a Xa25 Hegel p30 preamp jays audio CD3 mk3 transport with pacific dac
JLaudio f112 v2 sub. the clarity & imaging is excellent
Piega speakers are overlooked if you can audition them highly recommended
I have a Hegel H20 amp sitting since I put the XA25 amp in the system and one day will insert it back in the system but
the Xa25 gives me no reason to.
Axel C
12
8
8
NYC
I’ve since replaced the Wilson Audio Watt Puppy 7 (WP7) with their Alexia 2, and the Pass Labs XP22 Pre changed to a XP32 and again to a XS Pre.
With approximately a doubling of internal cabinet volume, newer drivers, and ~10 years of development know-how, it’s no surprise that the Alexia provides a larger soundstage and better articulated micro details than the WP7. In short, if you like the Wilson WP, you’ll love the Alexia 2. It’s not a radical change but simply better in every way (except in the effort to move and set them up!).
For the Preamp, the move from the XP22 to XP32 was not small. I was surprised by how much more info seems to get through punctuated by much better detail. It’s hard to describe but hearing is believing. I was very satisfied with the 32 but when an opportunity came to get a nearly new XS Pre curiosity got the better of me. Upon receipt, I played a half dozen familiar tracks on the 32 before swapping to the XS. Just before listening I remember thinking I’ll just resell it if I cannot hear much difference! But within the first track i was left stunned by how lush the same tracks played. The edges to every note seemed softer and the quiet between more pronounced. While the 32 is extraordinary, the XS lives up to its flagship status and is a clear step beyond. It also has the largest volume knob I’ve ever seen!
Lastly, I’ve since swapped all of my Audioquest interconnects / power cords and Transparent speaker cables for Nordost Tyr 2. While I know this is a rabbit hole and I won’t argue that it’s worth it, I’m also not going back. I think it’s quite true that with the right system synergies everything contributes to the performance. It’s up to the listener to decide their priorities.
I did all of my comparisons between speakers and pre amps before and after the cable swap, so all of the above opinions account for that.
Just wanted to share my experience as I appreciate so many I read from other members.
Reactions: RickS
Don Reid
91
94
175
74
My DIY, triamplified, fully horn loadspeakers are powered by a Pass Labs X150 on the bass and two First Watt F3s handling the mids and highs. My system also includes a XP-17 phono stage. I think the F3s are fabulous sounding amplifiers. They are even better than the Cary Audio 2a3 SET monoblocks they replaced. However I don't know that I would recommend them in applications where they would need to control a woofer.
