Should I use Speaker Spike / Isolation Base or Something?
Sangbro
29
9
3
41
Hello,
Some speakers have 4 sets of pucks (made of thermoplastic) in its bottom.
I think it would work great on hard floor.
But how about carpeted floor? Can I just put this puck foot on the carpet?
Or should I replace it with spike?
Or should I put kind of plate (Isolation Base) between the carpet and the speaker puck?
Or can I just use something like bamboo cutting board (from thin one from Ikea to 4” thick butcher board)?
What would be the best way? :)
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,010
1,320
Spikes on carpeted flooring. Please allow me to offer you a very warm welcome to the What's Best Forum.
Tom
Mikem53
662
581
105
I started on carpet with spikes, Then raised my speakers up by Using a 4” thick butcher block platform and spikes on the speakers into the wood plinth. It sounds better on the wood stands, but the height might have contributed to the improvements in my case..
Reactions: Sangbro
Sangbro
29
9
3
41
Tom
Thank you.
I have been doing some research and the results are indeed not conclusive as I thought.
Puck on carpet is a tricky business.
Sangbro
29
9
3
41
So far, if I take the spike route, it seems I need to put it down with enough height to stabilize the speaker solely on enough (2”+) height.
I think the idea behind this is separating the speaker from the floor.
Mikem53
662
581
105
my speakers are mid sized floor standers and I wanted to raise the tweeters a bit to ear level when seated. I also didn’t want the spikes to go through the carpet into the finished wood floor. Now the speakers are ground into the wood block on spikes. Spiking the speakers to the floor tighten up the bass
and grounds the vibrations to the floor.. Some decouple the vibrations or absorb. I’ve always used spikes rather than just setting them on carpet.
