Running Springs Audio fans?
kleinbje
181
24
923
CT
Everybody here seems to be hooked on Shunyata, but after careful comparison RSA was the only brand that didn't take anything positive away from the music. I'm using a Dmitri with HZ, several mongoose on sources and another Hz for the amp. I find they make an amazing improvement, anyone else a fan.
Jeff
LL21
14,430
2,518
1,448
Jeff
Would love to read any comparisons you could make if you don't mind...always enjoy reading those. I have heard great things about Running Springs. My local dealer only had access to Accuphase and Transparent, and I needed a serious cord extension since I melted the last one. Ended up with Transp Ref Power Isolator...nice difference. but again, did not have the opportunity to listen to Shunyata or Running Springs.
dan31
1,020
369
1,653
SF Bay
I have been using a RSA Haley for the front end of my system since 2007. No complaints and no itch to try something new. I believe the acquisition by API technologies has damped enthusiasm at most dealers.
JimmyS
163
34
335
Chicago, IL
I have been using a Jaco for all the front end components and a Duke for the amps for a few years to help with the lovely 1940's wiring in my Chicago house. No plans to change until the basement remodel happens to get dedicated power runs.
kleinbje
181
24
923
CT
For me the Shunyata's made a very black background and deeper bass, but they somehow took the enjoyment out of the music for me, it was if the life was sucked out. Now this is slightly hyperbolic, but it was the difference between listening with a smile and screaming **** that sounds amazing. The running springs seemed to do everything better with even more "draw you in" factor. This was even when I used the Dmitri with the stock power cord. When I added the HZ the bass and background were markedly improved. I then added a HZ to my amp and Mongooses all around, been very happy ever since. They are pretty reasonable on the used market. I like em better than the ztrons.
LL21
14,430
2,518
1,448
Many thanks! Enjoy. Most intriguing.
Champ04
72
2
6
Illinois
BIG Running Springs Audio fan here.
P.S. anyone who is a fan of the HZ might be interested in the info at CH Acoustic for future reference. (chacoustic.com/HZCrown)
KeithR
5,174
2,864
1,898
Encino, CA
Have heard this comment before on Shunyata, but no idea on the new products. I think too often, audiophiles focus only on bass and don't figure out the rest of the equation until its too late.
On RSA, my hesitation is really they are a cap company now, not a PLC one. I believe the lead designer moved on as well. I was very close to getting a Dmitri in-house.
Champ04
72
2
6
Illinois
Technically, they always were a cap company. But not just caps, all sorts of premium electronic parts. That's one of the things that made the PLC so good for the price. All of the internal parts were made by them as well. As far as I know, the only thing they didn't make on the PLC was the chassis. But you are correct, the designer has moved on. Which is why I always recommend that people buy older units as they come up for sale.
kleinbje
181
24
923
CT
I new they were purchased by API, didn't know he designer left. The current dmitri should have the same design, and I think it is still worth a listen. IT was the most significant component I added to my system as it makes everything better.
adamaley
588
546
228
Minnetonka, MN
After 6 years, the question still remains - what have owners of Running Springs Audio Power products moved on to, if at all. I have a Haley and am running out of outlets for my growing system; what with three new Linear Power Supplies in the last month. I'm interested in newer acquired replacements for the RSA products where you felt there was improvement in some or all areas, or simply a sideways move where nothing was lost.
JimmyS
163
34
335
Chicago, IL
6 years later, my running springs gear was sold to a friend and now using a Shunyata 6000T. Was already using Shunyata power cords, and I liked what they did in my system so I tried the 6000T. It brought an improvement in providing a lower noise floor, and I was hearing small details in music passages more clearly. The RSA products are still in my friends system, and performing well.
Reactions: adamaley
dminches
3,480
2,858
1,410
I have a good number of RSA conditioners but most aren’t being used now that I have an Equi=tech sub panel powering all my music room outlets.
If I had to start buying power conditioners again I would go with Audioquest.
Reactions: adamaley
