Rockport Arrakis (Latest) - Save $55,000, Worldwide Shipping
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
figure 'street price' on a new set is 30% plus off retail.....maybe more; what someone will actually pay. so that sets the value limit for used. but the listed value has to be kept high to protect the brand.
but this is likely the same set that has been for sale for at least 6+ months by owner.
someone will end up with these for a little over $100k when all is said and done......maybe up to $125k shipped. and that will be a great value for a super speaker system.
16,222
13,687
2,665
. . . someone will end up with these for a little over $100k when all is said and done......maybe up to $125k shipped. and that will be a great value for a super speaker system.
+1!
LL21: It is time to step up!
spiritofmusic
14,626
5,435
1,278
E. England
Hmm, for this price would you buy them, or the new Lyra model?
BMCG
234
41
133
United Kingdom
Given relative footprint...and ability to serve smaller rooms.....am thinking Lyra.
spiritofmusic
14,626
5,435
1,278
E. England
BMCG, unfortunately I can’t go as far as “thinking”, just “daydreaming”.
I always find one thing disappointing about these designs.
Everything is better generation to generation.
Except sensitivity.
Would it kill Andy to create a super speaker with sensitivity in the late 90s? So one could genuinely use SET amps with it?
Alpinist
530
143
280
USA
Rockport’s latest cabinet and cone technology and a more reasonable size that would work in more listening rooms. I would say advantage Lyra.
Ken
Audiocrack
2,187
696
1,158
Except sensitivity.
Get into the Tidal diamond range speakers (La Assoluta and Akira) where you can have it all: top notch performance and high efficiency, although not hornlike efficiency. Using set amps with my LA's.
bonzo75
22,650
13,685
2,710
London
Maybe for your third system you can get into horns, AC?
16,222
13,687
2,665
Unless I was limited to a small room which would squelch the Arrakis, I would take the Arrakis. I love the two Altairs inverted M-T-M design which, I think, affords a scale and grandeur which, I believe, only that speaker height can create.
Audiocrack
2,187
696
1,158
Very, very unlikely, Kedar, because I have never heard a horn loudspeaker that could convince me from top to bottom. So I suppose I am not a 'horn guy'.
The Rockport Lyra on the other hand might be a speaker that could really convince me. However, I want to be able to play my loudspeakers with my Kondo set amps. Likely that is not possible with the Lyra.
bonzo75
22,650
13,685
2,710
London
I haven't heard Arrakis, but I heard the discontinued, then retail 30k USD grand mira 2 (very different from the grand mira or mira 2).
I loved it, and then realized it was the only other model in the Rockport line up that was dappolito and MTM. Side firing and front firing woofers, it did things like many planars but with more weight, though depending on room one might have to supplement lower section with woofers. Like you mention, height it is important and it was 7 ft, and the side and front firing woofers made it appear faster than the zzzz ported cones.
I never liked any of the other Rockport models, having heard Aviors with different amps, (the altairs only at Munich with absolare each year)
So, I just put this out there for Rockport fans, or any cone fans, and for those who can't go anywhere near the arrakis, to keep a watch out for an used grand mira 2, at 10k to 15k it could be a bargain over some of the other cones. It is tall at 7 feet, slim, and the distance to side walls matters because of side firing woofers. If you see an used one fly over to check it out if you have the space. It is 90db, I heard it with a trilogy integrated and surely that can be improved.
bonzo75
22,650
13,685
2,710
London
That's coz extremely few exist. Custom ones can do it.
sbo6
1,679
606
480
Round Rock, TX
So you're saying to your ears the ~8 year old $30K Grand Mira bettered the newer tech and 3x price ~$100K Altairs? That's a pretty damning statement to throw out...
I've heard the Arrakis many times and the Aviors. Both have a slight darkness to their presentation (not in a bad way) and are ruthlessly revealing. Excellent speakers.
On a different note - I've never heard horns that I truly liked, even more so at given price points. Part, I'm sure is due to room size requirements which many (most?) don't have to accommodate.
bonzo75
22,650
13,685
2,710
London
No. To start with, it is the Grand Mira II, which I said is different from the Grand Mira and the Mira II. I caveated that Altairs is only Munich demo. But yes, I prefer the 7ft, Dappolito, MTM design to normal cones. Never heard the Arrakis unfortunately. And I am suggesting those looking for bargains should check them out when they come on the used market.
LL21
14,430
2,518
1,448
Today is not that day for me. But that day will come.
Til then, having heard 3 Rockports (incl Altair 2 and Arrakis) and enjoyed them each tremendously, I can say based on on those [limited] experiences, the Arrakis has an effortless scale that took my breath away despite having heard multiple big Wilsons, Focals and i can think of a few others for years (and having a big Wilson and sub at home). The only other speaker i have heard that challenges and i suspect can do even bigger effortless scale is the Genesis 1. But the footprint difference between those two makes the Arrakis seem downright economic by comparison. 2' x 3' footprint and 9 inches taller than a big Wilson. The Genesis panels are well over 7' tall and 4 feet wide each with a still not insignificant thickness despite being a panel...not to mention the 2 over 7' tall woofer towers...and other boxes that come with the speakers.
I really do like that speaker a lot. Great to see people are keeping an eye out for it! Thanks, Ron, for thinking of me. I will buy those someday.
BMCG
234
41
133
United Kingdom
Further on the Rockports...been a fan since Goodwins put the Altairs center stage....loved them.
Challenging to find them in the UK though...
Audiocrack...you are not helpful in suggesting the TIDAL Akira is a UK available alternative.....
and so I do not unintentionally insult....
The unhelpful part relates to ....yes I like the Akira (well except for the £200k part)....as I can't quite work out how to get the trouble and strife approval.
Man maths anyone?
Audiocrack
2,187
696
1,158
Man maths anyone?
Ojee .... and my intentions were so good ...but I understand ... all these 'damn' prices ... however, the Akira's are so good that imho they not only deserve your liking but also your (unconditional?) love ... so good luck with the maths and getting approval ... who knows?
spiritofmusic
14,626
5,435
1,278
E. England
I’m not really in the market at any of these prices.
I just don’t understand why in this day and age, it’s not possible to create a cost no object speaker with high efficiency.
90dB just precludes enough tube amps.
bonzo75
22,650
13,685
2,710
London
Wasn't that new Goebbel speaker that way?
