What the heck is a Phono Converter? It's our newest product and we're quiteexcited to give you a sneak peek. Take ahigh-end analog phono preamplifier and combine it with a state-of-the-artAnalog to Digital Converter and the NPC is what you wind up with.
Ready to ship this September, the NPC has the best analogphono stage we've ever built in our 30 something years of building phonostages. 100% analog from input tooutput, this is like our famous GCPH phono stage on steroids. Passive RIAA, a class A all FET gain stage,this beauty is quiet and able to handle just about any cartridge you put on it(it has 6dB more gain than did the GCPH). In a few weeks we'll have all the specs up on the website.
DSD as well as high resolution PCM
In addition to the analog phono stage we've also included awonderful Analog to Digital converter that can take either the output of thephono stage, or the output of any analog source you wish, and convert it toeither DSD or PCM. With this output youcan plug directly into your DAC and play records without any compromise.
Or, use the asynchronous USB output to feed the DSD or PCMsignal to your computer so you can build a digital library. DSD encoding is available in standard ordouble rate and PCM audio is capable of up to 192kHz, 24 bit. We've even added a Digital lens to the finaloutput to keep the digital audio sounding sweet and unjittered.
