OPPO media control
alfa100
266
49
333
South Africa
I’m unable to stream Tidal on my MSB transport which essentially is an OPPO BDP 103 . I’ve asked Tidal, MSB and OPPO. OPPO says that OPPO digital is no more and they cannot help with the OPPO media control App. I have tried mConnect which basically does Airplay and dies not sound as good. Also I cannot control CD player from the Media control app. Any suggestions ?
tmallin
WBF Technical Expert
May 19, 2010
972
390
1,625
71
Chicagoland
Try Googling "Oppo Media Control App" (no quotes) and download it to your smart device and see if it works on your MSB. It seems to be free from many sources so you have nothing to lose in trying it.
alfa100
266
49
333
South Africa
I have this app on my iPad and iPhone . It does not work anymore.
Armsan
219
229
275
Are you referring to Oppo Media Control UDP-20X last version 1.1.2.3788 from 2018?
Mine works fine to control the Transport, CDDA, USB drives and network home. No Tidal or Qobuz though.
From streaming app with renderer capability you have mconnect for Android and iPAD/iOS. Also with renderer capability and the best sounding app control, get a Android tablet/Smartphone and install BubbleUPnP.
Armsan
219
229
275
I believe you are referring to a 2014 Oppo Media Control. That one has/had streaming capability for Tidal. Don't know if it works because I only use Qobuz.
