30lbs of copper cable...yikes! very interesting to note, particularly given how some of the latest grounding cables seem to look like power cables now.
Yes Lloyd seems like people are catching on...but the great equalizer need not be expensive or cumbersome.
I recorded this Keith Jarrett piece from his Carnegie Hall concert today with about 1 hour warm up and the volume set @10'oclock.
Sir,
Is this on reel tape. Where can I find this on analog?
Kind regards,
Tang
Ok,for the those who follow my grounding escapades,the system is still morphing. I think it will take till the middle of next week before everything stabilizes. The increase in clarity keeps driving the ability of the system to take me into the music and in a way I personally have never before experienced. The biggest effect has been on orchestral music,not in a unnatural way,because the instruments are still layered correctly front to back. The dynamics and realism are what is profound in my mind.
So the bottom line is I'm going to defer from placing the last two straps on my mono blocks. This whole grounding process has been cumulative,so I might have reached the point of satisfaction. Currently I have on Prokofiev's 5th on DG ....stunning and extremely dynamic....we will see.
Sawasdee Mr. RogerD,
I went back to pg.15 and saw the pic you posted. You have one heck of a grounding sir. I too am a believer of grounding. I say you aint hear what your gears can give you unless you ground your devices.
One question. Does multiple grounding in a single gear has more effect than a single point?
Kind regards,
Tang
Hi Tang,
Good question....in my experience it doesn't matter as I have both single and multiple points on each piece of gear. What does matter is the size of the grounding cable. I now use zero gauge cable. Though to be clear I only use one point to mains ground.
Hi RogerD - apologies if you have explained this already but do you take all your grounds back to the earth of the power point in a star ground manner - I am quite interested in this as an alternative to systems such as entreq etc.
I have certainly found wire gauge to be an improvement in power supply cables beyond what you would expect and can understand why your approach works
cheers,
Phil
Lloyd I think you will find out if you continue to increase the grounding pathway,is that the 100 to 200 hour settling period is actually the reset of your current IC's. As the grounding circuit removes more noise the IC's will be a conduit connection between components to transfer a purer audio signal. The more noise that is removed the more tonal richness and clarity will be revealed. I have come to the conclusion as many here have that live music is the only thing to judge by. The only other arbiter is the ability to visualize (no better word) what the microphone would hear and that can only be accomplished by training yourself to listen for the degrees of clarity in that context in your system. In my experience there are many levels of clarity and that is the essence of this puzzle and the solution too.
My system is in my office room at work. Some days, it just gave me this extra extraordinary clarity. Even my wife asked what I did to the system. And she knew well how effective the Tipoint did to my systen because she helped me connect them. I went an insanely expensive way to ground my system with Tripoint. Still on some day, it sounds better than the other. I am in search for consistency.
Kind regards,
Tang
The system took a big leap forward late late last nite...and i was expecting that it was perhaps just the 'late nite thing' in audio in big cities.
Flipped the system on today to have some music while working this evening, and its just as killer as late last nite. Perhaps the system is indeed settling into a new level of clarity. took longer than i was expecting, but certainly not complaining.
Kind regards,
Tang
Interesting...i wonder if (like NYC and London in my experience), the electric 'grid' makes a difference. do you have anything between the public electric grid and your system? Some members here have large electric sub-panels dedicated to their systems only. We have dedicated lines with a backup battery power (mainly for loss of power) and still use a Burmester Reference 948 for the source/pre. Certainly seems to keep things more consistent than before.
(BTW, also a big fan of Tripoint...and its funny, after moving house and settling in with the system which has had some delayed upgrades...my wife and I finally got around to adding the final few wires to the Tripoint and fixing some other connections i knew had not been done right...took an hour of painstaking work for my wife and me! She was great about it...and now she's working while listening to good music.)
Hi Phil. My preamp is the main connector for all 8 other components. So the preamp PC is the single cable back to mains ground. All of the original safety grounds are left in place. Thanks for asking.
thanks Roger - I presume you take them back individually to preamp - I have constructed my own hardwired cable distribution box and filter using 40 x 5mm copper busbars and 5 G wire with the whole kit actively shielded with 12v via braided copper sleeves and copper mesh around filter box but I did not use large Gauge earth wire or shield it - your experience suggests I should go back and do that - or run a separate circuit as you have suggested
all very interesting
cheers
Phil
