metal conduit for interconnects
16,220
13,683
2,665
Is there any practical or theoretical sonic problem or issue with placing line-level, signal carrying interconnects in a metal conduit?
Has anyone found that encasing interconnects in metal conduit affects the sound?
16,220
13,683
2,665
ddk
6,261
4,043
995
Utah
Never done it but why don't you use vinyl or plastic pipes that we know won't affect the sound instead?
david
david
I agree . Why metal. Use PVC. Personally I would not be cutting into the slab of my house for the sake of hiding wires.
ddk
6,261
4,043
995
Utah
I wouldn't either but if you must then just put in conduits of sufficient diameter so you can snake the wires easily later. You certainly don't want to commit to wires at this point Ron.
davidn
Blue58
899
685
1,155
London, UK
david
Wouldn't PVC etc carry a static charge while a metal conduit could at least be grounded.
I may be wrong.
4,702
(...) Has anyone found that encasing interconnects in metal conduit affects the sound?
Although I never tried metal conduits, long ago I wrapped all my ICs and speaker cables with aluminum foil and connected everything to the ground. That time it was a complete disaster - it killed the system, making it lifeless and boring.
Remember that you will need large diameter pipes - some connectors are really thick.
DaveC
3,899
2,143
495
It's a bad idea to put them in any kind of conduit. Both metal and plastic will cause issues.
RogerD
3,734
319
565
BiggestLittleCity
RogerD
3,734
319
565
BiggestLittleCity
Knowing the cables Ron is considering this will be a large conduit. Hence cutting into the slab. This for me is a no go. I'd rather deal with the cables on the floor
Behind the wall or in the upper crawl space? Cutting into concrete is a "big mess' lot's of dust and it goes everywhere,structural?. Even if they can contain the dust...I would look for other options.
Leif S
770
166
180
California
www.vonschweikert.com
I agree. Getting a concrete saw in there and the mess it makes as well as the expense, isn't there any other options? A cable raceway molding or something? It is "Highly" recommended that metal conduit is not used. If you must go this route, use 4" PVC conduit. I'm assuming schedule 40 would be o.k. but should check. If memory serves, electrical lines are supposed to be run in schedule 80, but these are audio signals, not power cables.
I saw Dave C. said that either metal or PVC would both be problematic. Dave could you share why PVC would be problematic?
16,220
13,683
2,665
Thank you for your assistance and thoughts, gentlemen.
I have pretty much dropped the idea of the under-the-slab conduit (very expensive; limiting on cables; and perpetual worry about leaking) and so this raceway has to go on the floor (on top of the carpet) right at the five foot wide entryway/archway between two rooms. So there is a trip-over risk issue and a cosmetics issue.
Legard makes a fairly nice stainless steel box raceway, and that might be less unsightly than a typical rubber Wiremold Coreduct or a plastic box raceway. This conduit has to go across the entire five foot opening between the two rooms so the stainless steel raceway might allow it to look almost like a design element as opposed to a yucky-looking wire cover thing.
As David says, I do not want to commit to wires at this point.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
I would worry about conduit resonating or rattling behind the walls. If it were me, I would get some nice belden coax wire and run them now before the walls are up. It will cost next to nothing and doesn't need conduit. When the time comes you can experiment with using that, versus garden hose cables run the surface.
I think proper aesthetics of a room has value and one that is too often sacrificed with too much running from here to there in typical stereo systems.
On that note be sure to distribute enough outlets on the wall as not have to run long AC cables.
Leif S
770
166
180
California
+1
Joe Whip
1,740
563
405
Wayne, PA
I have never seen interconnects done this way but I have seen speaker wires run through PVC through a concrete slab. The slab was poured though with the conduit in place. No issues at all.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
There are companies that specialize in it. It is a massive, loud machine that cuts with water/diamond saw. So no dust. They get it done in an hour or two. I have had it done at my theater and the one at work. In the stage of construction that I think Ron is at, it is not a big deal at all.
