How to replace your home theater pre-pro with a HTPC!
mojave
251
Elkhorn, NE
Here is what Bruce B said in another thread but I'm not sure if it relates to your situation with three stereo DACs:
Well I'll tell you the truth... I have had every clock in here to test from the Big Ben to the Antelope Rubidium clock and neither has made a difference. You always... always want to use the internal clock of a DAC and make it the Master... IMO! I've tried using the Lynx Synchro-lock on their card and other such ways, but when you only have 1 converter in your system, always use the internal DAC clock. Manufacturers that use and sell you an outboard clock are just making money off of you... is the clock in their own DAC broken? Did they skimp on the clock inside?
Unless you are recording with multiple converters, such as in a studio or location setting, I never use an outboard clock, period!
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
"Using the clock in the DAC" as Bruce suggests implies you can run the DAC in asynchronous mode, which the MSB can. However, for MCH application with three DACs this does not work, because the MSB running asynchronously adds half a second delay, so the other channels would be out of synch with the mains on the MSB.
So for MCH, I need to run the MSB synchronously (i.e. disengage reclocking), using the masterclock provided by the Lynx card. However, Lynx mentioned to me that in their experience using an expensive word clock for the AES16e card does not get you better sound, so I'll probably won't be messing with clocks.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Quick question for the JRiver luminaries on the forum. I am trying to configure a rule for Jriver to switch to my multi channel zone when I play a MCH file. However, there does not appear to be a an attribute in the data model of the files that captures this property. Am I missing something?
Another option is to keep all the MCH files in a separate library, but then you need a rule that switched to the MCH playback zone when you load this library. Can this be done?
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Ladies and gentleman, it is official. Trying to configure an HTPC with a MCH zone based on Lynx card and a 2 channel zone based on SotM USB card and using Dirac Live DRC is a disaster. I wasted 3 days trying to get it to work, system behavior is completely erratic. Nothing works. I need to get really drunk tonight and come up with a plan B. Most likely, I will ditch Dirac and try to get at least the Lynx card and SotM to stabilize. Oh, did I mention my Trinnov processor died on me yesterday. Complete audiophile hell....
dallasjustice
2,067
8
Dallas, Texas
So you are trying to set jriver with different audio devices? You go out over USB for 2 channel and switch to Lynx ASIO for MCH?
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Yes. This turns out to be a complete nightmare. This stuff works if you set it up once and don't touch it. Change configurations is a recipe for disaster.
dallasjustice
2,067
8
Dallas, Texas
You think the ASIO drivers are conflicting with one another? Does your USB permit WASAPI or Kernel instead of ASIO?
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
In jriver you need to use wasapi to be able,to set Dirac as the virtual output device. In the Dirac processor you then switch between lynx Asio and msb asio depending on wether you want to use the USB output or the lynx. Switching between the two output modes in Dirac and between zones in jriver causes the problems.
dallasjustice
2,067
8
Dallas, Texas
It's been a while since I tried this. Several years ago I tried to do this with a single server and there were too many compromises for me. If I had to do it again, I would simply give up on the 5.1 or 7.1 bitstreaming.
Would you be willing to use the jriver internal volume control? You could send the main left and right AES to a really good reclocker and then the reclocker AES output to your MSB. I understand that wouldn't be synchronous, but you can measure the delay for the reclocker and the MSB buffer and factor that into the delay for your other speakers. This way, you are only using a single ASIO device; much simpler system design and you should be able to get equally excellent 2 channel sound. I don't know what the level differences are between your DAC and amp, but if they are paired well, you should be able to set the attenuation on your DAC so as to minimize the amount of 64 bit dither you use in jriver's internal volume.
I know this is not the "audiophile" solution. All I can say is you should at least try it out. I have done this with my DAC, and if it's set correctly, I can use as much as -14db of jriver internal attenuation and cannot hear any difference when compared to the totalDAC's 69 bit dither/internal data path with jriver volume control disabled.
Nyal Mellor
590
4
330
SF Bay Area, CA, USA
That's annoying! My configuration of JRiver auto switches from an AudioPhilleo USB/SPDIF converter to Lynx AES no issues.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I'll explore some options. I was planning to use Jriver volume control for my MCH system all along. For 2 channel I have my preamp. I am currently using not using reclocking of the MSB in MCH mode, because I cannot synch up the channels with the very long reclocking delay in the MSB. May be I should carefully compare SQ from the Lynx card with the USB route.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
You are using the on board USB, I am using the SotM card. Another wildcard are the new MSB Windows 8 drivers. I have a Windows 7 machine with Dirac and it works fine with the MSB DAC. I'll first uninstall the Lynx drivers. If this solves the problems, the ASIO drivers cause the conflict. If it does not, Dirac with MSB on Windows 8 does not work correctly.
dallasjustice
2,067
8
Dallas, Texas
You should be able to measure the exact propagation delay for your DAC or any other non-synchronous device. I believe this can be done using a loopback test. Once you know the exact propagation delay, you can fix that in the room correction tab in jriver. This assumes the delay is the same for each sample rate, which it may not be.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
I need to get the basics sorted out first. Will try to tackle the more complex stuff later. Just turning the MSB reclocking off works fine for the moment.
prerich
249
12
923
prerich
249
12
923
Fyi, all of you JRiver users - JRiver now supports the Silicondust HDHRPrime - I have now uninstalled Windows Media Center on my PC - don't need it for anything now. Works perfectly for my premium channels too!
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Is there any technology to do the same with satellite TV that you are aware of?
prerich
249
12
923
Not yet :( not that I know of. Let me get back with you on that.
