At this point EMT is simply a badge for Thales products. You’ll accept them if you like their house sound or hate them if you’re not a fan. Either way EMT exists no more. In a way it‘s been gone for decades.Looks like the Thales Slim.
The EMT 128 has a switchable Gain (64 and 70db), I had very good performance in using a Koetsu cartridge.EMT 128 phono stage sounds as good as the looks but requires a relatively high output cartridge.
What’s the deal with those tubes? Soldered in and if you need replacement you undo that one bolt and get a new tube and daughter board from EMT?EMT 128 phono stage sounds as good as the looks but requires a relatively high output cartridge. it’s hard not to be impressed by the build quality when you open the top cover.
probably yes. it’s not mine, a friend’s phono stage actually.What’s the deal with those tubes? Soldered in and if you need replacement you undo that one bolt and get a new tube and daughter board from EMT?
