(...) As you might guess from my job and previous posts (paying more than $30k/year for my daughter daycare tuitions) I'm not on the market for a half million dollar system. Something on the range of the Devialet could be the highest I would realistically imagine in my future.
The answer to your questions will be also determined by the type of music you mainly listen and your current speakers. Can we know them?
I mostly listen to classics of rock and progressive.
Respectfully, though, I think that a good performing system should behave good regardless the music style. I'd rather be concerned with the speaker design with regards to the music genres...
It's the same issue with plugging in DSP into your chain - a conversion can never be better than the original, and likely, worse. The problem is that with the Devialet's architecture you have no way of knowing how this conversion affects things, because there is no analog-only path in the unit to compare with. It probably is OK, but then again, how certain will you be... said otherwise, has anyone ever been convinced that an additional ADC-plus-DAC path will be equally good (if not detrimental) than a direct-analog path? Some would say yes, and to that I would say, wow, you have just found the absolute perfect ADC/DAC device! Having said all this, one might successfully argue that RIAA EQ is better done in digital than in analog, but how do you really know...
IMHO you have to think of a system as an whole - both the amplifier and speakers should match your musical preferences. If you listening in an apartment (perhaps not your case) you will not be able to listen at the loudness needed for full immersion in the classics of rock and progressive. Than you will need an amplifier that highlights the rhythm and fluidity of music, showing the tunes inside the music. Curiously I have found that the DartZeeel integrated was much more adequated to this type of music than the Devialet. Surely YMMV, you should listen to it!
It should be noted that I only had the Devialet Premier and the DartZeel in my system - the new Devialets were only auditioned at dealer auditoriums.
BTW, if I only listened to Piano Concertos I would own a Devialet - it sounds really great with this type of music.
So, this thread is staying very interesting! Thanks to all the contributors.
To Microstrip:
I did listen to the integrated Dart. But it was only at a trade show, driving speakers that were unknown to me (Kudos). Sound was fine, but I was not impressed... Otherwise, it provides a compact and full functioning (apart for the digital...) component, still having a conventional approach.
I would definitely like to audition that with speakers such as the WA Sophia III.
to be clear; there are two completely different darTZeel integrateds.
there is the CTH-8550 which is a conventional integrated including an internal moving coil phono stage.
and there is the brand new LHC-208 "Danalog" streaming dac with integrated amplifier. and unless you happened to be at 2014 CES in January or at the Newport show this past June......you have not heard this one. and as much as I like the CTH-8550, to my ears this new 208 is better sounding (I've not heard them side by side.....so that is just my perception). it seems to have a bit of the magic of my 458's in it's dna.
so if you've only tried the 8550 then you have not heard what I'm talking about.
Anybody who believes that there is something inherently wrong with digital is unlikely to be persuaded away from that view by a newbie like me posting, so for them, stop reading now...
I have extensive experience of making both analogue and digital recordings of both music (as an amateur recordist for 50 years) and the output of other sensors for engineering data (and a microphone is a sensor, like any other, so as far as I am concerned accurate recording is just that whether of a microphone or any other type of vibration sensor).
I have -never- used an analogue recorder which was accurate, in as much as the output and input were indistinguishable. In the case of engineering data that meant that one had to be very careful, re-calibrating recorders daily and paying particular attention to the known shortcomings of the recording process in the interpretation of results, and for some things they were completely useless.
In the case of music recording all the inaccuracies of an analogue recorder other than speed stability are euphonic, so that whilst not accurate they do sound nice. The fact that they are not accurate is easily checked if using a tape recorder with off tape monitoring capability where the difference between microphone feed and off tape are clearly different.
Digital recording is IME nowadays "sufficiently accurate". An anti-aliasing filter is vital at the recording stage, and a reconstruction filter at playback, otherwise the hogwash about step sizes and so forth becomes true...
On the sort of music I have recorded I can not hear the difference between the microphone feed and the output of my ADC/DAC. Maybe on some sorts of music or non music sound I would be able to hear a difference, but up to now I can not.
My conclusion is that digital is much more accurate than analogue for recording/replay and for me so far transparent, i.e. the input and output are indistinguishable by me.
In the case of other recordings I can attest that digital recorders have allowed me and other researchers to discover fine details which analogue recorders are demonstrably incapable of.
As good ADC/DACs have proved to me that they are transparent to my ears it is a reasonable for me to assume that, since the Devialet has a well engineered ADC/DAC that it will be transparent to my ears.
In fact, since the way the Devialet works reduces the analogue stage to its very simple essence I could be convinced that a transparent ADC/DAC followed by a simple elegant analogue circuit is likely to be more transparent than a complex analogue circuit subject to all sorts of potential losses and interference.
RIAA correcting in the digital domain is a no-brainer if you have the signal in the digital domain, using an analogue circuit for it will be less accurate and very much more expensive.
So having explained where I am coming from I can also say I have auditioned the Devialet phono input at several stages of its evolution.
First I had a home demo unit in late 2010/early 2011. I was quite impressed by how quiet the phono stage was, but expected my Goldmund Ph2, which probably cost more than a Devialet, to be better.
I eventually bought a D-Premier, and after quite a lot of listening settled on using the MM input of the Devialet and my Ortofon T3000 SUT rather than the Goldmund phono stage.
I am still using the Devialet phono input. It sounds fantastic IMHO but its biggest gain over the Goldmund is how quiet it is.
I believe that the Devialet matches electronics many times its price. The reason for this is clever engineering IMHO. The very expensive analogue part of this amplifier is very simple, and most of the complexity is done in DSP at relatively low cost and complete transparency (IMO).
High quality analogue kit has to have many more super expensive components if it is to be any good, so I would expect to produce an analogue pre and power amp to match a Devialet in sound quality may well cost 10x more to manufacture.
Having written all that I know plenty of people who prefer a bit of euphony to transparency, so I would recommend a home demo with your own TT and spend a bit of time with the configurator optimising the input for your cartridge.
I see nothing 'wrong' with digital.....and listen to it daily in a few different formats. it's good, to very very good, to really good. I'm listening to 2xdsd ripped vinyl right now.
that said....there is a very large difference between accurate and complete. and when I want my world rocked I'm choosing complete.....which is analog. vinyl or tape.
I respect that you have done recordings, and have your world view that you have. but I've been involved enough with pro audio guys and their hirez recordings to know that they cannot digitally copy my vinyl in a way that gets it all. and I have also seen where the right analog tape deck does get it all.
it was telling to watch the pro audio guys faces when we A/B'd the hirez digital rips with the direct feed of my turntable. a telling moment.
which does not in any way invalidate anyone's enjoyment of the Devialet phono stage.
Well if by "complete" you mean with some euphonic colourations added, my experience would be in agreement with your opinion.
OTOH I have -never- heard audio or used for data recording a tape recorder that does not add something to the signal. So it is creating a bit of extra sound of its own, many people like this addition including, evidently, yourself.
They are incapable of recording correctly the microphone or other transducer. That is a demonstrable fact, despite what your pro-audio friends faces may look like![]()
And tape recorders are -much- less compromised than record players.
I suppose it depends on how one defines 'correctly'.
Dear Mike,
with all due respect, fundamentally you are repeating web "knowledge" that is false IME.
As I wrote originally, those who believe there is something wrong with digital shouldn't read my post!
I always think of digital recordings as presented in "letterbox" form as opposed to full screen or even Cinerama of Analog. Now the majority of original analog recording transfered to digital lose less in the process. Only a few DDD recordings sound Analog to me and that is more the engineer than the shortcomings,but the talent needed to produce a comparable digital recording to a fine analog speaks for itself.
I have always remembered this quote from Steve Hoffman the mastering engineer....
"SH: Let's look at what a CD actually does. Take a piece of paper and draw a wavy line to represent the sound wave. Your CD samples each part of that wave. Instead of one wavy line, you're getting Morse-code -- dot-da-dot-dot-dot. Our human ears are used to hearing things in a certain way. Some of us who are familiar with live music in the concert hall would notice the lack of ambiance on certain CDs. Loss of ambient information becomes obvious. So do harshness, dryness, and other baddies, when we know what to listen for. Mastering engineers try many ways to circumvent that. There are multiple styles of analog-to-digital converters. Some are better with ambiance; some are better with other [things.] I like to add a little extra ambiance at the beginning so that when it slips through the cracks, there is still enough to sound lifelike. Certain types of tubes have a coloration that give an overabundance of ambient sound. "
http://www.stevehoffman.tv/dhinterviews/Hoffman_TAS.htm
Another good read
http://www.endino.com/graphs/
And Steve Hoffman was wrong. That view of digital is simplistic and wrong.
Now about the recordings themselves: Some ( a lot of) analog recordings lack ambiance too or what have you . it is a matter of recording and mastering. Let's leave that part off please . Old repeated cliches that bear not a resemblance to the facts.
If you like analog please enjoy it and in that case the Devialet is not for you. It is all digital, even the "analog"portion is digitized prior to amplification. It would be however educative and interesting to hear it one of these days, try to put prejudices aside... And since you have that thing about "noise" whatever it means to you ... The Devialet is the most "noise"free electronics I have yet heard.
