Hi
The BADA DAC II does most things right. I rarely indulge into audiophile-speak terms like"organic","pace"and the likes. For starters it is dead quiet. Not in the sense of hearing hiss or other nose. Most modern DACs are quiet. It is in the sense of the music delivery that simply comes out with no noise attached or added. This happens a lot in other form of medium. You raise the volume and you grind your teeth some.. The music is louder but comes with some "grunge" (here I had to go into audiophile-land
) we are supposing amplifier with adequate power .. Not so with the DAC II .. Music in all its glory, regardless of the volume setting of your preamp (or better use it directly to drive your amps). I have found many TOL DACs trying to smooth out the 5~7 Khz region to sound somewhat more analog. While many do succeed you get a sense of limited treble extension although they can and would measure flat almost everywhere. There is a rounding of the edge of instruments in that region for example. A solo from a violin, a very strident instrument BTW that we audiophiles have come to prefer to hear in a editorialized "sweet" way though our electronics, to continue a volin solo does if well recorded, comes out like it supposed to, with the BADA, many other DAC get part of it right especially in the lower register but up there you are supposed to hear the greet and stridency of the violin, many celebrated DACs go out missing by a footbal field length. Same with the mid-bass to me an extremely critical area , where the foundation of many music is. The BADA has it right. weight when necessary, articulation too. IT remains agile many DACS add some artificial weight to the mid-bass or simply eviscerate it, adding a bit of either dryness or a soft fuzzzy, overly warm midbass.. Not the BADA. Bass .. One of the best bass from a DAc IMO.. matching the best I have heard in from a DAC the Burmester CD/player DAC in that area, fro those who have heard the Burmester 061, that is not a small feat. (On that this remains in my view of TOL one of the 5 best DAC , i find it strange that Burmester has decided to drop their standalone DAC and rather go with a CD/DAC player instead , strange, same with Spectral as many are finding that there is no reason to use an expensive transport when a well tune PC works much better ). As for the sense of space it is as good as it gets, the instruments and performance venues are well reproduced.. CLear and with a sense of rectitude: Nothing added, change of venues from recording? Change of the sense of space. Contrary to many TOL who seems to have a wide soundstage when there should be a very small one ... We fall for this so often it is not funny: The audiophile cliche of "wide stoundstage" .. This soundstage often remains wide regardless of the relative size of the venues. Seductive? maybe. Realistic? Not at all.
I want to hear the BADA Reference to see what it brings to the table at almost 3 times the price ...
