Classical Avantgarde
Al M.
8,810
4,553
1,213
Greater Boston
Gary Koh asked me on another thread where the topic came up to start a thread on (European) classical avantgarde. Here it is (it is not limited to Europe, for example one CD recommendation below is by an American composer).
Background
After WW II, a group of composers, among them Boulez and Stockhausen, wanted to start with composing from scratch, instead of building on established traditions. Initially they started with ideas like 'total serialism' where not just pitch is treated in a series like in 12-tone music, but other parameters as well, such as duration and dynamics. Based on such ideas, certain 'gestural languages' (see below) were developed. Rhythm is often irregular. These gestural languages in turn became the basis for, and were augmented or transformed by, other methods of composition unrelated to serialism (Xenakis for example was never a serialist), or serialism was only loosely applied as an abstract concept and became what could be called 'serial thinking'. As composer Richard Barrett puts it, "it’s not a question of relating everything to a “series” but of relating everything [all musical parameters] to everything else". (Explained in more detail here: http://richardbarrettmusic.com/Stockhausen2012.html) Stockhausen for example has applied such 'serial thinking' to all his compositions including those without any pitch series, but still has based a substantial portion of his output on pitch series nonetheless.
One thing that should be kept in mind is that most great composers of classical avantgarde (past and present) were and are not just wild boys who wanted to be different solely because they did not know enough about how to write 'normal' music. While mostly eschewing 'traditional' forms of musical expression such as themes or melodies (at least in the common sense of 'singing' melody), they were and are well trained in 'traditional' composition techniques and have studied them. For example, Boulez could not be a famous conductor (an occupation that has limited his compositional output in the last few decades) if he were not well versed in classical music theory, and Stockhausen has written scholarly works on Mozart and Bartok and has shown himself to be an able Mozart conductor in the two works he conducted, flute concerto in G and the clarinet concerto. Also, Stockhausen has composed marvelous youth works in a more traditional style (e.g., the a cappella 'Choirs for Doris', with Doris being his later wife) and returned in some of his later music to a more melodic writing, in which he proved himself, at least to my ears, as an incredible melodist (while most of the time, yet not always, his melodies are still more abstract than common ones). Electronic musicians generally admire Stockhausen as a pioneer and a composer of electronic music (he also has been called the grandfather of Techno), but one reason why few electronic musicians can emulate the quality of Stockhausen's electronic music is that they mostly do not have the impressive 'tradtional' compositional skills that Stockhausen has.
What not to listen for in classical avantgarde
As mentioned, there are hardly any themes or melodies, at least not in the common sense. Also, don't try to find a 'series' -- your search will mostly be in vain. If a work is based on a pitch series, it is mostly an abstract relationship that is not readily detected by ear, nor is it composed to be detected as such, but rather is just a compositional template. In fact, since the music as it sounds is not about that, in general it would pervert the composer's intention to search for "the series". And that is, if there even is any; as mentioned, there is also a lot non-serialist avantgarde, and most more recent avantgarde is of that variety as well. And in more melodic works, like some of later Stockhausen, the series mostly just forms the basis of diverse melodic gestures, but is not the melody itself.
What to listen for in classical avantgarde
Listen to gestures, such as characteristic brief pitch and rhythmic motions, or patterns of such motions, which may recur in constantly varied forms. Listen to the motion of the music in general. Mostly there is no typically flowing motion like in music with regular rhythms, but there can be gripping motion nonetheless, irregular and fractured as it may be. That fractured motion often plays out in a constant game of tension between subsequent and/or simultaneous musical elements. In fact, once you get the hang of it, avantgarde music with its abstract, purely gestural language may actually be easier to listen to than 'classical' forms, where it is often desirable to attentively follow the thematic development in order to experience the continuity and logic of musical flow, especially if the listener wants to consciously experience the music as a conceptual whole rather than just a nice collection of beautiful moments and sounds washing over him/her.
Also, listen to just the sound. Unlike 'classical' music where sound is rarely a means to itself, but serves melodic or thematic expression and development, avantgarde music is often composed as mere sound, or gestures in sound. In fact, some of the early avantgarde composers (e.g, Stockhausen, Xenakis) became pioneers in electronic music in part precisely because they became interested in just sculpting sound from the inside out, and in developing new sounds. But sound as such is also important in a lot of avantgarde music for acoustic instruments.
Al M.
8,810
4,553
1,213
Greater Boston
A few musical suggestions
Pierre Boulez, Repons (1984)
http://www.amazon.com/Boulez-Répons-Dialogue-lOmbre-Double/dp/B00000IIZ3
A collection of shimmering patterns of sound. Here you actually have a lot of 'running' motion, among others. Won a Grammy in the early 2000s.
Xenakis, La Legende D'eer (1977)
http://www.amazon.com/Xenakis-Electronic-Music-Vol-Legende/dp/B0007RFGU0
Electronic music.
Wolfgang Rihm, Jagden und Formen (1995-2001)
http://www.amazon.com/Rihm-Jagden-Formen-Wolfgang/dp/B0000630QB
Complex polyphony for 23 players. Sonically perhaps one of the very best recordings from DGG, a label not typically known for stellar sound quality -- a killer.
(See also my review there [Albrecht Moritz])
Charles Wuorinen, On Alligators, diverse works by this American composer
http://www.amazon.com/On-Alligators-C-Wuorinen/dp/B0006SNLJS
(See also my review there)
Maxwell Davies, Symphony No 1 (1976)
http://www.amazon.com/Maxwell-Davies-Symphony-Mavis-Vegas/dp/B007829HOS
Maxwell Davies, Naxos Quartets Nos. 7 & 8 (2005)
http://www.amazon.com/gp/product/B000NOIWQC/
Richard Barrett, Dark Matter (2003)
http://www.amazon.com/Dark-Matter-Barrett/dp/B009IQA0WK
Richard Barrett, Transmission
http://www.amazon.com/Barrett-Transmission-Elision/dp/B000FKP3WK
Works for each one of these solo instruments: contrabass clarinet, percussion, trombone, violin, electric guitar
The guitar piece will blow away any lover of electric guitar!
Fausto Romitelli, Professor Bad Trip (1998)
http://www.amazon.com/Fausto-Romitelli-Professor-Bad-Trip/dp/B0001EKZJ6
A psychedelic trip for instrumental ensemble (featuring electric guitar) of much more intensity and outlandishness than typical 'psychedelic' rock music. Not only does Romitelli evoke strong, robust atmospheres, the finesse and nuance of his handling of variations of gestures or gestural complexes is among the very best in music.
Stockhausen:
Gruppen (1955-57), Punkte (1952/62, revised 1994)
http://www.amazon.com/Karlheinz-Stockhausen-Gruppen-Punkte/dp/B000ENC6P0
Gruppen for three orchestral groups is a Stockhausen classic, Punkte a completely different orchestral work.
Yet even when you have heard these two works, you really will have no idea about Stockhausen's style. In fact, he has no 'style' -- practically every work is completely different, even more so than with other avantgarde composers (mostly the examples provided above represent only a small portion of their 'styles' as well). You will also have no idea about his later more melodic music, some of which may be sampled here:
Amour (1977), Wochenkreis (1986), Der kleine Harlekin (1975)
http://www.amoeba.com/amour-der-kleine-harlekin-wochenkreis-cd-karlheinz-stockhausen/albums/3047635/
http://www.amazon.co.uk/Stockhausen-Amour-Wochenkreis-kleine-Harlekin/dp/B00F3YZDHS/
While I have not yet heard this particular CD (but do know all this music), I trust its quality since I know the interpreters on this disc. For my review of Wochenkreis, see here:
http://home.earthlink.net/~almoritz/wochenkreis.htm
Wochenkreis (cycle of the week) is in my view one of the most stunning melodic inventions by Stockhausen, or any composer for that matter, even though again, the melodic writing may need to get used to (it also took me quite a while to fully appreciate its quality).
Other than these CDs, my best recommendations would be for CDs from Stockhausen Verlag (including their, originally DGG, Gruppen recording which, while much older and of lesser sonic quality, is actually clearer and sounding in musical terms than the above one).
Stockhausen Verlag CDs are available here:
http://www.karlheinzstockhausen.org/cd_order_form_2013_english.htm
They are more expensive than the typical CD. Once you are ready to take the plunge, I can give suggestions. There is a lot of Stockhausen on youtube, mostly illegally uploaded which I cannot endorse; I suppose it is mostly in mp3 quality.
In my view, Stockhausen is the greatest avantgarde composer of them all, both in terms of producing the most varied and consistent body of high-quality music which is large as well and in, more than others, pushing the envelope in practically every single work all the time, until his death in 2007, more than half a century after his beginnings in the avantgarde scene. Not just that, I consider him one of the greatest composers of all time. I say this while I know the classical repertoire rather well and deeply love the music of the old masters. Just recently I have been re-listening to a lot of Beethoven string quartets (Emerson Quartet) and his Ninth, and have enjoyed once more several Bach cantatas and Bruckner symphonies.
Here is my website on Stockhausen's music:
http://home.earthlink.net/~almoritz/stockhausenreviews.htm
ack
May 6, 2010
6,774
1,198
580
Boston, MA
Thanks. I admire you for understanding Stockhausen; if he could only keep his mouth shut on 9/11
Al M.
8,810
4,553
1,213
Greater Boston
Yeah, but that is long forgotten. See for example this article on WQXR which serves the New York City area:
Top Five Reasons Why Stockhausen's Music is Hot
http://www.wqxr.org/story/275802-top-five-reasons-why-stockhausen-music/
See also this article in the NY Times:
Hanging In With a Demanding Composer
Stockhausen’s Work Flourishes Five Years After His Death
http://www.nytimes.com/2013/07/14/a...ive-years-after-his-death.html?pagewanted=all
...and this glowing review in the NY Times of 'Michael's Journey':
http://www.nytimes.com/2013/07/20/a...ork-has-its-north-american-premiere.html?_r=0
The electronic Octophony in NYC in March 2013 was in such popular demand that they had to offer several more performances.
Talking about 'Michael's Journey' (a sort of trumpet concerto), I forgot this important recommendation:
http://www.amazon.com/gp/product/B009EP39SC/
Same performers that played in NYC (sonically excellent recording, too). It's some of the more melodic Stockhausen, but pretty far out there.
4,704
It was surely a very poor moment, and he regretted it and apologized. But I have read in classic music magazines that he later considered that the press distorted it a lot, taking his words out of context.
4,704
Great start Al M. Nice to remember that some of this Avantgarde people also composed charming music!
Al M.
8,810
4,553
1,213
Greater Boston
Many thanks, Al M. for starting this.
You're welcome, Gary.
I've subscribed, and will be exploring this music.
That's great to hear! I will look forward to your impressions, but give yourself some time. Like with any new music, you may or may not like what you hear initially, but given your musical curiosity I am sure you will eventually find something that you like.
Al
Al M.
8,810
4,553
1,213
Greater Boston
Yes, that's true. They play Stockhausen's Tierkreis (Zodiac) melodies on the Bell tower of the Cologne Town Hall. Maxwell Davies has written children's tunes, as well as popular-style songs in some of his operas. The composition Mavis in Vegas, coupled on CD with his rather abstract first symphony (see above) features some nice tunes as well.
