Can Sony's volume limit on EU models be overridden?
freddyfreeloader
3
London
Hi all
I have a Sony Walkman NWZA-15 A, bought in England that has a European Union regulations volume limiter. It's not loud enough!
Does anyone know how to override the volume limit?
Thanks
Freddy
awsmone
1,616
514
435
Canberra Australia
Hi all
Thanks
Freddy
I am suspecting the issue is the impedance of your headphones
I wonder what set of headphones or impedance this unit was tested with?
Have you tried different headphones?
freddyfreeloader
3
London
Hi
It's not the headphones, in the European Union, many audio products have a built in volume limiter so as to avoid hearing damage. The government feels that it's its role to tell citizens how loud they can listen to their music.
awsmone
1,616
514
435
Canberra Australia
Hi
Apparently this is a common problem
Try resetting the device
Also there should be a menu in settings to override the volume limiter at 30
freddyfreeloader
3
London
This problem can't be solved in the normal way, setting, resetting or adjusting the device ordinarily. What's required is a non-standard workaround that someone 'in the know' will be able to advise of. But thanks anyway.
