It only had 1 usb.Does the P1 USB cable have two legs? If so, connect both. P1 should be connected before server is booted. CD drives are recognised automatically so long as they are connected before startup.
Tried that, still doesn't work. First time ripping CDs. Tried another CD that didn't work as well. May be its an issue with storage location?
I have a 2TB SSD in the bay in CX. Where do I set the storage location?
Storage location for CD rips is set automatically (/storage/music/flac folder). Check that the CD Import app shows under Apps. If it does click the icon and you will see ripper progress. If it does not show install the app from Apps/Software Manager/Available Apps.Tried that, still doesn't work. First time ripping CDs. Tried another CD that didn't work as well. May be its an issue with storage location?
@td19 THANK YOU!!!!Storage location for CD rips is set automatically (/storage/music/flac folder). Check that the CD Import app shows under Apps. If it does click the icon and you will see ripper progress. If it does not show install the app from Apps/Software Manager/Available Apps.
Just installed it! Thanks !!On myantipodes.com, if you select the Apps tab, there is an app where you can kind of watch what's happening during import. Did you happen to find that?
Mine only has 1 USB. May the new vs old?perfusionist,
It appears you are getting your results now. On post #221, you indicated only 1 USB, but believe there are two USB connections split on the cable from the P1 to CX, https://www.antipodes.audio/models/product/antipodes-p1/
Follow the instructions on post #204.While I'm in the stretch of EX/CX posts, I don't seem to be able to update either of mine to 2.8 from 2.7. Is this something I should be able to do myself successfully with the console/app? It appears to "work" in the logs, but after reboot it remains 2.7 on both units after multiple tries.
what am I missing?
a. One usb on the P?Mine only has 1 USB. May the new vs old?
a. One USB on the P.a. One usb on the P?
b. One port only on CX?
c. All of the above?
perfusionist,
Thank you. Interesting, I previously has thought all P1 came with the dual male USB.
Worked for me a few days ago, but it assigned a new fingerprint for the embedded HQPlayer so my license key didn’t work. Jussi seemed to reluctantly issue a new key after requesting. He didn’t think the fingerprint would change. But it did.
Sold my EX+CX. Ordered a K50.
