Another playback software to argue over
Gregadd
1,791
1,850
Metro DC
You can only get so far arguing about test procedures. Bias is only one aspect of testing . By far not the most important one. We realize it is the crown it is the crown jewel of the objectivist camp. Brand name recognition is a good thing. Experience is a good thing. We don't have to start from scratch every time evaluate a product.
Julf
613
Amsterdam, The Netherlands
But isn't the logical implication of that that the answer to the question "do all bit-perfect players sound the same" is "no, it depends on the brand label"?
Phelonious Ponk
8,677
23
Tim-Again I say that expectation bias that leads you to think that what is new that you bought based on cost, brand, reputation, and build quality sounds great either will sound great over the long-term or it won't. Those with decent ears will be honest enough to admit they made a mistake if over time they come to realize the new expensive brand name gizmo with great build quality doesn't sound as good as what it replaced.
I understand that this is your position, and however long it takes you to decide something sounds great, I hope you then enjoy it for many years.
Tim
Gregadd
1,791
1,850
Metro DC
Sounding the same is not the goal of most manufacturers
Forgive me for "fighting your hypothetical"
I so frequently encounter so many qualified claims like "any competently designed... or working within its range... and in our case "all bit perfect players...
For the sake of argument I'll great your premise "all bit perfect players sound the same."Are their brand names I can rely on to make a bit perfect player?Assuming that there are manufacturers who don't.
Julf
613
In computing terms, I call that a bug, not a feature.
I wasn't actually arguing that point. I just picked the "bit perfect" one as being at least somewhat topical. Are there any audiophile features/tweeks/"differences" that, in your view, make no difference, or do you think absolutely everything matters?
Anyway, let's pick something that really isn't going to make a difference - magic crystals, or a plastic insert between your power plug and the wall socket. My point is that according to your logic, you might still hear a difference - depending on the brand and manufacturer of the crystals or insert.
Gregadd
1,791
1,850
Metro DC
"In computing terms, I call that a bug, not a feature."
Most would call that innovation or progress: The notion that I can do it better.
"I wasn't actually arguing that point. I just picked the "bit perfect" one as being at least somewhat topical. Are there any audiophile features/tweeks/"differences" that, in your view, make no difference, or do you think absolutely everything matters? "
It does not matter because i granted your premise.
That is too comprehensive a question to answer here. I will venture that over my audio journey things that i thought did not matter, turned out to make a difference.
"Anyway, let's pick something that really isn't going to make a difference - magic crystals, or a plastic insert between your power plug and the wall socket. My point is that according to your logic, you might still hear a difference - depending on the brand and manufacturer of the crystals or insert."
"My logic?"
For any claim to be credible it has to be effective. Companies that have a history of doing just that deserve consideration when they claim they have perfected extraordinary products. Or improved on existing ones.
