Aesthetix I/O Phono Cable
Joenies
8
6
5
74
Greetings
What type of phono cable do you use with your I/O, balanced or SE?
When I decided to upgrade my phono cable for my I/O I asked my audio dealer about getting a Balanced cable, since the I/O has Balanced inputs. My audio dealer informed me that the designer of the I/O (Jim White) doesn’t recommend using a balanced cable for the input. He supposedly recommends a SE cable. My audio dealer tried to explained to me the technical reasons Mr White prefers SE cable over balanced. I didn’t understand te explanation at that time. I took my dealers advice a purchased a SE cable for the phono input. I use a balanced cable for the output.
I don’t think my dealer would mis-inform me about proper cable choice.
‘To those that use a balanced cable, any problems? Has anyone tried both types of cables?
Did I make the wrong decision going with a SE cable?
It sounds very good to my ears.
Your input will be greatly appreciated
‘Respectfully
Joe Nies
dan31
1,020
369
1,653
SF Bay
You are fine using the SE cable input on your Io. The first stage of the Io is SE. I use the single ended RCA input as well.
