Hi,
I wish to know more about motor noise from AC or DC motors. Previously I have used an SME 20/2 and its motor was very quiet . I visited a friend to check out his AirForce III and although the air bearing was silent the motor was not as silent as SME 20/2.
I want to know the level of normal motor noise from different turntables. If you put you ear to the your turntable's motor, is it dead silent or do you hear the some noise?
Thanks
Thanks
