I have been researching AC line frequency and high-end audio solid-state amplifiers.
The question is: is there any problem or issue (electrical, sonic, thermal, safety, etc.) whatsoever with feeding a 60 Hz AC line frequency to a solid-state amplifier designed to operate at an AC line frequency of 50 Hz? (Obviously the amplifier designed for 50 Hz must be fed the AC voltage for which it was designed.)
The answer seems to be that the steel core of a transformer designed for 60 Hz AC which is powered by 50 Hz AC can be saturated and draw excessive current and the transformer can overheat. However, a transformer designed for 50Hz AC which is powered by 60Hz AC experiences reduced idle current and actually runs a littler cooler when powered by 60 Hz AC.
So, my tentative conclusion is that there is no problem whatsoever powering a solid-state amplifier designed for 50 Hz mains with 60 Hz AC.
Do you agree?
Thank you.
Do you agree?
Thank you.
